Rinaishlene Posted October 20, 2005 Report Share Posted October 20, 2005 Hi I has designed a schmitt trigger switch which suppose ly to light up an LED when the input voltage increses to 8V and light off the LED when the input voltage decrease to 4V.The design req for the project is to have only a single power supply 12V,an uA471 op-amp and a npn BJT transistor.The opamp portion successfully acts as comparator but the problem is with the switching network where the LED just stays on and doesn't go off as required.here I attached the cct for reference. Quote Link to comment Share on other sites More sharing options...
audioguru Posted October 20, 2005 Report Share Posted October 20, 2005 Hi Rin,Welcome to our forum. ;DLook at the datasheet for the 741 and you'll see that its output voltage can't go low enough to turn off the transistor. Add a resistor to ground at the base of the transistor to form a voltage divider of the output from the 741.Since the transistor's base-emitter voltage is much lower than the voltage at the output of the 741 when it is high, then the small current in the added resistor won't affect the transistor when it is turned on. ;D Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted October 20, 2005 Report Share Posted October 20, 2005 You might also need to use a lower value for R5 as the transistor might not saturate enough to turn on the LED fully, I'd go for 47k maximum and connect the base to 0V with 10k. Quote Link to comment Share on other sites More sharing options...
Rinaishlene Posted December 5, 2005 Author Report Share Posted December 5, 2005 Well thanks for responding :)But there is nothing I could do to improve my cct operation :( because i read your both reply pretty late.....(by the time I read it,I had finished presenting and submitting report on the circuit design).However ;) ,I planned to try to implement your ideas on the circuit when I got back to campus after this semester break.Thanks to both of you Quote Link to comment Share on other sites More sharing options...
