Jump to content
Electronics-Lab.com Community
Sign in to follow this
thunder
hot air gun
i've bought a hot air gun mashin '"i don't know really wut terminolgy is used for dis mashin but i name it hot gun'' 4 desolding smd chips but i don't know how to use it  , it has 2 variable controles one is for air pressure and d other is 4 heater
so any one can help me abt dat wut tempreture and air pressure is normally used and there is othere tools like penses N paste plz give me information abt dat
Share this post
Link to post
Share on other sites
Hi thunder,
If the equipment has a name and number on it try to Google it and you might find a manual for it. Or go to the manufacturer’s homepage and you will find the necessary info. 8)
Share this post
Link to post
Thunder, since this is an International site and many, perhaps most members, do not use English as their first language, perhaps it would be easier for others to know what you are saying if you do not use slang or abbreviated synonyms and numbers for words. You might get more help with requests. Just a suggestion.
Thanks,  ;)
MP
Share this post
Link to post
hi
thanks Mp for your guidance
i just wanted to know about the tools which are commonly used for desoldering. about my device it's made in china and there is no doubt that this has been made at home ,so no manifacture's name and address ,
Share this post
Link to post
Guest Kasamiko
Hi Thunder,
I've been using China made Hot-Air Rework Station AEOLUS brand model 850C to do some SMT/BGA soldering and desoldering..
There is NO PERFECT setting for this since it is dependent on:
1. Line Voltage
2. Nature of Soldering (with groundplanes, heatsinked?)
3. Precised setting can only be determined by experience  ;D
As a rule of thumb, I start at 5 for AIR and  5.5 for HEATER
Good luck
Rhonn  ;) ;)
Share this post
Link to post
high kasa miko,
look !  tell me how should be the position of the heat gun , should i start from the corner of chipset or apply it to all sides? and the other question is till wut tempreture the ic can resist?
thanks!!!!!!!!!!!!!!!!!!!!!
Share this post
Link to post
Guest Kasamiko
Don't direct the heat ing the MIDDLE of the chip..if it is a BGA type..use a good quality flux and rotate the nozzle around the side dont stay in one position..
Heat only the the pins of the chip..
rhonn  ;) ;)
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
