Jump to content
Electronics-Lab.com Community
How to make an audio console's power supply better?
Dead_Nid
Hi Nid,
Nop I have not, I just can’t see why it should be that important in the rectifier stage. At least not if you already got your diodes or bridge rectifier bypassed with caps like I described earlier.
BTW. I have not encountered any regulators which oscillate from low ESR caps.
Link to comment
Share on other sites
  • 2 weeks later...
Happy new year to everyone!
Haven't tried any special diodes yet. I want to ask two very newbie things that I am curious about:
1) My PSU uses two 4700uF smoothing caps (in parallel so total capacitance is 4700x2). I am going to replace them because they are very old. But as the opportunity arises I could replace with greater capacitance. Is that better in smoothing quality (apart from space and cost issues)? Remember, this an audio mixing desk's power supply. So...I am thinking of placing 6800uF or 10000uF and that will mean a total of 13600uF or 20000uF...Even theoritically, is there any benefit as the capacitance gets higher and higher? Is there any chance that it can cause trouble instead?
2) What about voltage ratings? I was told (by Dan Lavry) to use caps with voltage ratings as low as possible. But in some manufacturers charts I have seen that the higher the voltage rating the lower the impedance. Any clue?
I am between BHC, Nichicon and perhaps Black Gate caps. Any suggestions?
Thank you! Best regards and happy,creative 2006!
Link to comment
More is not always better. There are dangers in making your cap's too large..... i.e. how would you limit inrush current?
For the most part, the ripple is "more" a function of ESR. Most times cap's are put in parallel to get ESR down instead of capacitance up. Lower voltage cap will give you a higher capacitance in the same size package. Depending on the voltage levels, you might be able to use cap's from Oscon.... they are VERY, VERY GOOD in terms of low ESR!!!!!
Link to comment
Hi Nid,
A Happy New Year to you too! ;D
The higher capacitance will lower the ripple (if any ripple exists), that’s the benefit.
Yes, as indulis says: inrush current can get you in trouble (maybe) depends on the rest of the circuit and how much higher value caps you use. However it is not the capacitance itself which is the issue, it is the ESR since this decides the level of the current. In other words; same uF but lower ESR might increase the inrush current anyway.
Inrush current is the current at powerup when the caps are drained and is “filling up” energy from the transformer through the rectifier diodes.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
