Jump to content
Electronics-Lab.com Community
Low drop out voltage regulator with TL431 Problem!
Hi
I want to build a Low Drop out voltage regulator(LDO)
I tried the schematic Below but the output Changes when I change the input voltage.
I wrote the voltages I measured at Vi=8V.
I put that 8.2K and 2.2K to create a voltage devider at the base of NPN tarnsistor because the lowest voltage i could get of TL431 was around 1.8V So I affrade maybe the NPN do not gets Off.
I put the other 2.2K to creat Enough current for TL431.
the output of this circuit should be 5V. The reference voltage of TL431 is 2.5V
ThanX in advance
Shahriar
Link to comment
Share on other sites
The open loop gain is far too high.
Ante,
The potential divider between pin 3 of TL431 and the base of Q11 reduces the gain if you reduce the 8k2 resistor on pin 3 then the gain will increase thus making the problem worse!
I think you should increase its value and connect a 1nF compensation capacitor across the TL431 and 100nF followed by 100uf on the output of the whole regulator.
By the way, there are better ways of doing this using a MOSFET, if you're interested I'll post a schematic.
Link to comment
Horray, this site is back "on the air". ;D
I fixed the circuit so its voltage regulation should be superb.
I added a couple of diodes to raise the base voltage of the NPN transistor to closer to the absolute minimum 2.5V required at the cathode of the TL431. I also calculated the minimum of 1mA (a little more when using standard resistance values) for it.
When the input voltage is high, the TL431 "zener diode" current is also high since zeners and shunt regulators waste a lot of current.
If the circuit is built with proper close parts layout on a pcb then maybe it won't oscillate since the TL431 has compensation for its own gain built-in. If it does oscillate then a 0.01uF cap can be added between the cathode to adj pins as in the datasheet. ;D
Link to comment
audioguru,
A 741 is compensated but if you added a transistor amplifier with enough gain in its feedback loop it would oscillate because there would still be gain when it's output is 180o.
Link to comment
ThanX all for your replies and your Pictures.
At last I made this circuit working. I was sure about my circuit wirings and I was really disgusted. Do you know How I solved it. Look at the picture below:
I don’t know much about Zero and Poles in Feedback circuits. But I think this cap will do something with Poles of the circuit. Before this I thought these poles are not very important…..
At last I connected the output of circuit to Oscilloscope, Wow, without that cap that output was oscillating very neatly and as soon as I connected the Cap the output was a Clean +5V DC Voltage. I have attached the output signal without a cap.
Dear Staigen
ThanX vey much, I think you solved the problem. the time difference between your replies and when I read them, causes I work a whole day on circuit. when you type the replies I am sleeping and when I write questions, you are sleeping.
at last If I had checked the ouptput with an Oscilloscoe then I would take result a 12hours earlier. 8)
Dear Audioguru,
are the values which you have written, from a circuit or you have witten them from simulating. anyway, I am going to test the circuit you have drawn. (I build the circuit on a BreadBoard!) :D
By the way, when I just Inserted a 1nF cap between Pin3 and Pin1,(while there was no output cap) the output was still oscillating but the amplitude was smaller.
ThanX All again
Shahriar
Link to comment
The best way to picture a TL431 is to see it as a transistor with a 2.5V saturation voltage and a base voltage of exactly 2.1V and a very high gain and base impedance, in fact you can actually use the TL431 as an amplifier in pretty much the same way you would with a transistor.
Phase shift and oscillation in amplifiers
Voltage regulators are basically DC amplifiers and are just as susceptible to instability as any audio amplifier.
Phase shifts caused by parasitic capacitances in amplifiers can lead to oscillation when a large amount of negitive feedback is used, here's an extract from a college assignment I did a couple of years ago that covers this and here's the datasheet for the 741 op-amp discussed
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
