Jump to content
Electronics-Lab.com Community
I am new to electronics but understand many principles. Very fascinating stuff.
In my mind I would think it possible to control up to 256  outputs from an 8 bit input such as a parallel port controlling home automation relays/devices.
I will not need all the outputs but would like to learn how to create such a project.
Could someone help me with the basics and logic and get me pointed in the right direction of thinking here.
Thanks very much.
Scott
Link to post
Share on other sites
Hi Scott
start small and build up to it...
the previous post will get you initially 4 bits, building up from there (16 possibilities and beyond) There are things like the 8255 chip which will expand an 8 bit interface.  Lots of PICs allow multiple I/O ports which can then be used to drive the outside world.  There are many processors like the ST10 range which, if memory serves me correctly, will drive directly 114 I/O ports.  There are also 8035/8041 derivatives with different ranges of I/O.
I know it's not easy but you have to try to define your requirement and then work backwards to try to find a minimal/low cost solution whicih will satisfy the original problem
Best of Luck
Ed
Link to post
One method is to use a 4 port microcontroller and connect the port pins in a matrix. 16 ground pins and 16 control pins in a matrix will give you 16x16 combinations, or 256. You would change the data direction in the code to allow for 8 of the port pins to be inputs when needed. You could insure the matrix was not effected by this with a few diodes.
If using the parallel port of a pc, you could add a 8255 and associated hardware to expand it to a 24 bit input/output port.
MP
Link to post
Did alot of research on this topic. With all the help you gave, it steered me in the right direction.
I ended up working up a simple 64 output using
9 - 74xx138 3 to 8 decoders
Using one as an address bus and the last 8 for outputting.
Now I just need to research latching the outputs. I think maybe a D-latch flip-flop (if that sounds right) is the way to go.
Again thanks for the brain fuel.
Scott
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
