Mukhalled Posted December 2, 2005 Report Share Posted December 2, 2005 Hi,How can I see if this effect transistor 2SK2605 works normally? should i test it just like the other transistors? you know a transistor has B C E , the 2SK2605 has Gate Drain Source.Help ;D Quote Link to comment Share on other sites More sharing options...
audioguru Posted December 2, 2005 Report Share Posted December 2, 2005 Hi Mukhalled,It is a high voltage and high power Mosfet, not a transistor. Its gate doesn't have a connection to its source and drain.Look at its datasheet and read about how Mosfets work in our Articles section. ;D Quote Link to comment Share on other sites More sharing options...
Mukhalled Posted December 2, 2005 Author Report Share Posted December 2, 2005 Hi Audioguru Quote Link to comment Share on other sites More sharing options...
audioguru Posted December 2, 2005 Report Share Posted December 2, 2005 You must turn it on to see if it works. Put a little 9V battery from its gate (+) to its source(-).Then your ohm-meter should measure close to a short from its drain (+) to its source (-). Quote Link to comment Share on other sites More sharing options...
Mukhalled Posted December 2, 2005 Author Report Share Posted December 2, 2005 Thank you so much :) Quote Link to comment Share on other sites More sharing options...
