Jump to content
Electronics-Lab.com Community
Posted
hi all,
Could anybody please elaborate how a jammer actually works? Does it have a particular bandwidth of operaton or it jams all the frequencies in a particular region?
Also, if an antenna is a transmitting device what happens to a signal which is at the limit of the antenna capacity distance? It gets jammed or is unpredictable?
shiks.....
Posted
Hi shiks
Whilst I have no 'hands-on' experience of jammers, from what I've read, this is a big subject...
If you are talking of radio reception jamming, this means making the reception of radio signals unintelligible or impossible in a particular region.  At least two and many other ways to do this,
1. Is to use the original transmission and retransmit with a time delay or several time delays with antennas beamed to the place you want to cover, making the reception tedious in the extreme.
2. Is to use the transmission frequency and beam 'white noise' at much higher power than the original into the chosen region thus drowning out the original signal.
It really depends on who/why the jamming is being done.  There may be very good reasons why only one or several stations are being jammed and that others may be allowed to be received.  So, it can be selective - If you wish to deny a region communications entirely then you would use several high power, broad spectrum jammers and antennas.  If you wish to obscure one station then a high power, restricted bandwidth transmitter would be appropriate.
Does that help?
Ed
Posted
Thanks Ed..
Jammers must be using too much power then, to operate !
Well do the different types of antenna also have their individual properties? Which one is the best and mostly used?
Posted
    I don't know anything about jammers but if anyone comes up with a personal cell phone jammer that say jams any reception within 15 yards let me know. I hate feeling like a ease droper.
                              gogo
Posted
  Thanks Ante & tnk2k
This means, a mobile jammer exists.It is portable and can be used as a handset like any other mobile handset.
Is there any area which needs to be improved? Any innovation.....?
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
