Jump to content
Electronics-Lab.com Community
Trace current limitations
mumcs01
I've done a few projects making my own PCB using standard mil traces, but overall have never concerned myself too much with trace size because everything I was doing was low current/voltage.
Well I've kind of crossed that line, and I've built up a project that is tripping a 120VAC relay (NC side, not coil... Coil is 5VDC), and the device I'm powering off of this relay has the potential of 900Watts.. So potentially 7-8 amps. The relay and the terminal block that I'm feeding the device off of are rated far beyond this (10Amps), but by question is, is there a chart or guide or article anywhere that approaches the limits of trace size (like the limits of wire size). My relay and terminal block are PCB mount, and I really would like to keep everything on one board instead of running leads places.
Any input would be great. Thanks,
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
