Jump to content
Electronics-Lab.com Community
Posted
I've trying to understand the relationship btw voltage and battery with no luck. As we know, there is voltage between + and - terminals of a battery. Thus an electric field is built up.
Posted
Your battery doesn't have a load so current doesn't flow. Electricity needs two wires to close the loop for current to flow.
I don't like Duracell so I chose Energizer, but connected them in series like your circuit, then added a 1k resistor as a load for 3mA of current to flow:
Posted
What do you think about my little experiment audioguru?
It is too confusing and expensive to short the battery for current to flow. I showed how connecting a load to the battery will cause a predictable amount of current to flow. ;D
Posted
Why dont you use Tudor batterys instead, then everything would have been much simpler?
You woulden't need any ground connection, and could refer to any of the three terminals!
Tudor, the battery with nine lifes!
[move] ;D ;D ;D
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
