Guest 12412 Posted February 12, 2006 Report Share Posted February 12, 2006 Any one no where i can get some cheap led??? It would be great if they also give out samples ;D.Thanks ;) Quote Link to comment Share on other sites More sharing options...
gogo2520 Posted February 13, 2006 Report Share Posted February 13, 2006 Check this outhttp://www.mpja.com/category/LEDs/LEDs.asp have fun gogo Quote Link to comment Share on other sites More sharing options...
Guest 12412 Posted February 15, 2006 Report Share Posted February 15, 2006 Sweatness, Thanks ;D Quote Link to comment Share on other sites More sharing options...
cntransportation Posted February 19, 2006 Report Share Posted February 19, 2006 You can find all the cheap leds you want @ e-bay canada. or on the net !! try searching these first <best hong kong,u bid it now and top bright led store. They sell anywhere fr 20.00 to 40.00 a hundred. There are some low prices at these stores from time to time so search often for the best deal !! Quote Link to comment Share on other sites More sharing options...
gogo2520 Posted February 19, 2006 Report Share Posted February 19, 2006 Check this outhttp://www.web-tronics.com/bagolred5mm1.html100 leds for $1.50 thats $15 a thousand. gogo Quote Link to comment Share on other sites More sharing options...
cntransportation Posted February 19, 2006 Report Share Posted February 19, 2006 These leds that r available at bagoleds are very low brightness and are also colored leneses. Depending what u use them for,,,they ers low quality and dim !!! Perhaps you need them as an indecator only,,then they era fine for that ! But if you are using them to light something you will want to buy higher quality such as the ones with clear lenses and alot higher mcds normally sold at best hong kong on e-bay !! Quote Link to comment Share on other sites More sharing options...
Mike11298 Posted April 27, 2006 Report Share Posted April 27, 2006 Dont forget the free samples Grin search someplace like globalspec.com for the parts you need, then see if that company offers samples --- many do. Quote Link to comment Share on other sites More sharing options...
MP Posted May 2, 2006 Report Share Posted May 2, 2006 Check this outhttp://www.web-tronics.com/bagolred5mm1.html100 leds for $1.50 thats $15 a thousand. gogoFor what it is worth.....I have purchased several hundreds of the "Bag of LED" deals from Circuit Specialists in the past. Have never had a problem with them. They are standard brightness LEDs and are not like the newer super bright ones that are available today..... but then, I am from the generation where LEDs used to be very expensive. These have been plenty bright for all of the projects that I have worked on.If you are using LEDs as a lamp, you certainly need to pay attention to specs on brightness. However, if you just want a standard LED, these are great.MP Quote Link to comment Share on other sites More sharing options...
