making a speed control for a 38 volt dc motor
Thanks for responding to my post. The only other thing on the motors tag is peak current rating:12 amps max. As far as the budget goes, I've don't have any idea what electrical components cost so I dont have any set amount in mind. At this point any suggestions would be great!
Dear,
There is so many choice for you to use.
1.If you are design a good products,you can choose the MCU to control the PWM CHIP to control the Motor
2.you can use a Mcu with a PWM output to control the MOS transistor to control the motor
3.If you just to design a easy tool for yourself ,you can use the adjustable resistance ,and the NE555,to output the different pulse width to control the MOS and then can adjust the DC motor.
1.Extract the code for you from programed Mcu for legal use
2.Specilized in the Microwave sensor,automatic door sensor,infrared sensor
3.OEM PCB and design for you in China
www.wafersensor.com
[email protected]
MSN:[email protected]
