Shahriar Posted March 4, 2006 Report Share Posted March 4, 2006 HiHave you ever gone to a Library, and when you are reading a book, you need to take some notes of the book. You have probably found it disgusting!The Problem is worse, when there is a picture in that section.If there was a device which you could take it to library, and when you need to take a note, you just put it on the book and drag it over that section to save that part in Memory. Then when you came back home, you could upload it in PC and do everything you need!What things you should do to build such a device?ThanXShahriar Quote Link to comment Share on other sites More sharing options...
Staigen Posted March 5, 2006 Report Share Posted March 5, 2006 Hi ShahriarA scanner do that for you, they have that at the Library, or at least a copier! :)Than you scan it in when you come home. ;D//Staigen Quote Link to comment Share on other sites More sharing options...
Shahriar Posted March 5, 2006 Author Report Share Posted March 5, 2006 Yeah, Thats right.but for using a Scanner, you need a PC for every one, and every few minutes you should put that Heavy book in the Scanner.Sometimes, There are lots of solution to do a job, But I think the important is which way is The best.If you yourself were in a library and you could choose between a Scanner and this device, Which Would you choose.... ::)ThanXShahriar Quote Link to comment Share on other sites More sharing options...
Staigen Posted March 6, 2006 Report Share Posted March 6, 2006 HiThis device, can you describe it, is it something you are building, some sort of project or something?Else you could take your laptop and a handscanner to the library! Dont they have a scanner? ;D//Staigen Quote Link to comment Share on other sites More sharing options...
