Jump to content
Electronics-Lab.com Community
5ohm 20watt resistor
shaiqbashir
Hi guys!
well! i want a 5ohm-20watt power resisitor. First of all please tell me that whether this resistor is available , i mean that is this a standard resistor. And im having some problems finding this in the market. So please can anybody tell me some alternatives to this. I have heard from one of my friends that we can make a resistor according to our required resistance and wattage by using a coil wire by using the formula:
R=pL/A
well! by this i can find a required resistance but how to find a coil of the required power. that is 20 watts.
ur early reply shall be highly appreciated./
take carez
Regards,
Link to comment
Share on other sites
If you need exactly 5 Ohms (this one is 25 W) and surface mounting is ok here is an alternative: http://www.elfa.se/elfa-bin/setpage.pl?http://www.elfa.se/elfa-bin/dyndok.pl?lang=en&dok=1775.htm
If you can live with 4.7 Ohms (standard value) you have many options.
Hope this is helpful.
Link to comment
It looks like they do not keep the search criteria in the link for very long at Digikey. Hmmm....I did not know it expired.
It is a Digikey part number HLWB-5.0-ND. It is a 5.0 OHM 5% 20W TUBULAR Wire Wound Resistor @ US$ 3.38 for qty 1.
Here is the datasheet from the manufacuter, Vishay.
http://www.vishay.com/docs/30210/hlwnhlw1.pdf
Hope that is more helpful.
MP
Link to comment
  • 6 months later...
  • 3 weeks later...
  • 1 month later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
