ECA TTL/CMOS-disk with pinouts data (RARE!-WANTED!)
Spaceboard
Here you can dowload one of the most wanted disc about electronic TTL/CMOS IC's. You can find Pin-outs, Datas, Logical Tables and more...
ECA is one of the bigest manufacturers and suppliers with data caracteristics in electronic theory.
This is ECA TTL/CMOS-Disk 2000 Database + Serial included and it is tested and works 100%.
If anyone of you guys have TDV-disk please share it with us. It is more wanted than TTL/CMOS. Thanks. (If you have something about electronic on CD please let me know, all find the way for share it :))
Dowload:
http://rapidshare.de/files/17021572/Pictures_From_Hollyday.rar.html
Password:
cheers
P. S. Don't worry about the filename this is not my Holiday pictures for certain.
Cheers.
Hi @Spaceboard,
Thank you for the link ;)
What is the TDV-Disk ?
Was it, or is it a ECA-CDROM product ?
Do you mean the ECA VRT-Disk ?
If it is the "ECA VRT-Disk 2005" you are looking for, then you can download it via eMule.
Search ("Global" and "Any"):
"ECA Disk" (89 hits) or "ECA" (Very messy, 534 hits)
Additional information (According to peers, these files are fakes or have no serial):
"Eca - Vrt 2005 (Completo) By Posada.nrg" (644.65 MB) is a fake, it's an AVI-file.
"eca_vrt-disk 2005.mdf" (787.06 MB) has no serial number.
Also make shore you download all the serials in the TXT-files (14 to 600 Bytes), just in case.
"eca_vrt-disk-2005.iso" (658.75 MB)
"ECA VRT-Disk 2004 Imagen CloneCD + Serial.zip" (300.58 MB)
"ECA vrt-disk 2002 semiconductor data base.img" (738.80 MB)
All came in like a bomb ! :o
Instalation of ECA CDROM Programs:
Warning !!!
Don't connect to the Internet while installing ECA programs, and don't agree to updates or any other kind of connection mode, for these programs will then become useless !!! :'(
Enjoy !
Cryonic.
Oh, thank you for reply, I'am not searching for ECA VRT-Disk 2005, I'am searching for ECA TDA-Disk that is very rare for download but exist somwhere... You can look on ECA site (www.eca.de and choose english if you like) about this product. This disk have data about transistors only (Pinots, hfe, comarasion, case, all currents, voltages, and other tehnical data you can imagine). This combines thousands of pdf documents in one single program (disc database). If anyone have it, at least let me know I'll find the way to catch and upload it somwhere so other people can have this precious thigs.
P. S. Other similar things are welcome too.
Hi @Spaceboard,
Please check out "FRANZIS" on eMule (122 hits). It's all in German, but excelent information! :o
Hi @Jwildes,
Here you have a brief explanation about certain file formats:
Source: http://forums.afterdawn.com
1) What is a .BIN? What is a .CUE? What is an .ISO
The .BIN / .CUE CD image format was made popular by the CDRWin software. Afterwards many programs have started supporting or partially supporting it, including: Nero, BlindWrite, CloneCD, FireBurner. The .CUE file contains the track layout information, while the .BIN file holds the actual data.
.ISO is also a CD image format, but is sometimes used for 'ISO9660 format' (Standard, recognized by all applications) and sometimes for unique Easy CD ISO format.
2) I have download .BIN&.CUE/.ISO files - what to do with them?
You can burn them to a CD-R or a CD-RW with:
- Alcohol 120% - Excellent software, easy and yet very advanced (Burns ISO, BIN/CUE, CCD, CDI, BWT files!).
- BlindWrite - Easy to use.
- FireBurner - Also very good, a single .EXE file!
- BurnAtOnce - A handy and FREE tool for burning .bin/.cue/.iso. Easy to use!
- Nero - Many of you have this, but the older versions can't handle all image files (Please check for plugins updates).
- CDRWin - This is the original BIN/CUE software.
You can also mount image files as virtual CD-ROM drives using:
- Alcohol.
- Daemon Tools.
There are also several softwares you can use to exploit & manipulate BIN/CUE files in various ways:
- CDMage.
- IsoBuster.
3) I have a .BIN file but no .CUE?
.CUE can be made by using your Notepad. A typical Playstation (1 or 2) .CUE file looks like this:
FILE "image-name.BIN" BINARY
TRACK 1 MODE2/2352
INDEX 1 00:00:00
A typical PC CD-ROM .CUE looks like this:
TRACK 01 MODE1/2352
INDEX 01 00:00:00
"image-name.BIN" being the name of the image file (IWDII.BIN, CIV3.BIN and so on...)
Notice the difference of the track mode - PC-ROMs being Mode 1, Playstations CDs Mode 2 and (Super) Video CDs are also MODE2/2352.
4) How do I make .BIN/.CUE files?
CDRWin or the BIN/CUE format is not ideal for distributing. BlindWrite suite and CloneCD perform a lot better in this purpose and can also handle various copy protections. Both of these softwares can also create .CUE files for increased compatibility.
5) I have a .BIN & .CUE, but my CD writing software can't locate the .BIN file?
Edit the .CUE file with Notepad (Or similar) and verify that the FILE "C:\path\image.bin" matches the location of your image file.
6) My image file is IMAGE.BIN.EXE and I can't rename it!
Read here:
http://forums.afterdawn.com/thread_view.cfm/23982
7) Sector sizes of CD image files (By Aldaco12).
When you talk about images must think on SECTORS not on DATA SIZE.
The rules are:
1) A standard 74 min CD is made by 333,000 sectors.
2) Each sector is 2352 bytes big, and contains 2048 bytes of PC (MODE1) Data, 2336 bytes of PSX/VCD (MODE2) Data or 2352 bytes of AUDIO.
3) The difference between secor size and data content are the Headers info and the Error Correction Codes, that are big for Data (High precision required), small for VCD (Standard for video) and none for audio.
4) If you extract data in RAW format (Standard for creating images) you always extract 2352 bytes per sector, not 2048/2336/2352 bytes depending on data type (Basically, you extract the whole sector).
This fact has two main consequences:
a) You can record data at very high speed (50x) without losing information, but if you try to do the same with PSX or Audio you get unreadable CD (For PSX) od audio CD with lots of clicks because there are not error correction codes (And error are more likely to occur if you record at high speed).
b) On a 74 min CD you can fit very large RAW images,up to 333,000 x 2352 = 783,216,000 bytes (747 Mb). This should be the upper limit for a RAW image created from a 74 min CD. Remember that if you store standard data (Backup files), you can burn only 333,000 x 2048 = 681,984,000 bytes (The well known 650 MB limit).
Please note that an image size is ALWAYS a multiple of 2352 bytes (You extract SECTORS), if extracted in RAW mode.
Regards,
Cryonic.
All I get from eMule about FRANSIZ is:
Franzis Audio 180% v2.0 Crack- Keygen - Serial.zip
Franzis Audio 180% v2.0 NoCD Patch - Crack-Serial.zip
| Scanner Frequenztabelle 27 MHz -10 GHz (Funkschau - Franzis') komplett.rar
| Franzis Scripting Host Toolkit - tobtools.rar
(ebook - german) Access 2002 programmieren - Echt einfach [Franzis, Axel Borntragerj.zip
| Franzis Finanzfuchs Haushaltsbuch 2005 (Deutsch) Vollversion.rar
| Franzis Elektrotechnik Formelsammlung Interaktiv.rar
| Netzwerk - Home Netzwerk - Franzis.rar
(ebook - deutsch) Netzwerk - Home Netzwerk - Franzis.zip
! Franzis. Audio. 180%. RiPPED. [uH ARC P ACKED]-SCORPiON. rar
AVR-Risc Mikrocontroller (Buch + CD-ROM, Franzis).zip
| Das grosse Werkbuch Elektronik 2002_by Franzis. rar
Das Grosse Werkbuch Elektronik Franzis 2002.zip
Franzis Audio 180% Full Iso -Scorpion.rar
FRANZIS. Audio. 180. Percent. v2.0. GERM AN-DVT. by. GEAR. for. www. goldesel. to. rar
(eBook) Franzis' - Das groRe Werkbuch Elektronik. rar
Franzis. Lernpaket. Schule. und. Abitur. 2006. DVD. ISO. www. eself ilme. com. part 2. rar
Franzis. Lernpaket. Schule. und. Abitur. 2006. DVD. ISO. www. eself ilme. com. part 1. rar
Franzis. Lernpaket. Schule. und. Abitur. 2006. DVD. ISO. www. eself ilme. com. par 13. rar
Franzis. Prof essionelle. Schaltungstechnik. 2. CDs. Nero. Image. rar
Dreamweaver MX echt einfach - Praxiskurs (Franzis-Verlag).rar
I am asking you: What to download? (tell me the filename and eMule server where to search)
Thanks. Cheers.
Hi @Spaceboard,
I mean these CD's from FRANZIS:
Franzis Professionelle Schaltungstechnik - CD 1 to 7:
Schaltungstechnik (CD 1)
Design Labor-Electronics Workbench (CD 2)
Praxis 1500 Schaltungssimulationen (CD 3)
Schaltungssammlung mit 10000 Beispielen - Teil 1 (CD 4)
Schaltungssammlung mit 10000 Beispielen - Teil 2 (CD 5)
Elektra2000 Mit Design Labor (CD 7)
Elektrotechnik Formelsammlung Interaktiv (CD 6)
The CD numbers may differ a bit, so please check first !
Also:
Elektor - The Datasheet Collection 1-2-3-4 with Menu (Kevlar).iso (695.13 MB)
Note: If this file is not complete, then you can download the separate parts 1 to 4.
Search: "ELEKTOR"
Also interesting from FRANZIS is:
Franzis PC-Hardware.pdf
And more ........
Happy downloading !
Cryonic.
Hi @Spaceboard,
These CD's are all about education in electronics, and are also very useful as a resource (Schematics) for the electronics engineer and hobbyist. They are also interactive, with several thousand simulations and examples. As usual, made with German Grundlichkeit. I don't know if the eMule versions are complete, or lack FRANZIS newest updates. There  is also a hardcopy version of this set, which may also be on the CD's. I have not checked and tested the downloads yet.
Here you can read more about this set "Franzis Professionelle Schaltungstechnik (5 Doppelbande)":
http://www.terrashop.de/77234386A/artikel.php?r=rel_list
http://www.terrashop.de/12751412/isbn-3772343864/bk_info.php
Enjoy !
Cryonic.
