Jump to content
Electronics-Lab.com Community
Data Transferrinf Over a 25 Meter Wire.
Hi
I am designing a new Language laboratory System.
I want to send serial data via a Common bus to all Stations (Students devices).
The length of this bus is around 20-25 meters. Which method is the best
for transferring Data. I mean FSK, RJ485 (if I wrote it right), SPI (that I don't think it work) or ...
The Baude Rate is Around 9600 bps
ThanX in advance
Shahriar
Link to comment
Share on other sites
Thank you very much for your reply.
Master Should send Data to all slaves and Retrieve some data from each Slave.
Just like a I2C Bus System.
But the difference with this system and a Small I2C Bus System is Distance between Master and Slaves.
BTW, Each Slave is a MCU Based Circuit.
ThanX
Shahriar
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
