Jump to content
Electronics-Lab.com Community
Testing Mosfets
Virus
Hi guys
Is there a way of testing a IRF510 mosfet to determine if it is blown or not. I believe these things can blow with static, etc.
I am building a circuit from a diagram with not much knowledge of electronics, and need to make sure of the Mosfets.
Thanx
Virus ;D ;D ;D
Link to comment
Share on other sites
:)yes look in the high voltage stuff section at my simple n channel mosfet tester  it will test them all . and if you want to test the p channel mosfet you just have to change the circuit around , the n channel mosfet testor only has 5 parts i think if i remember corectly
Link to comment
Steven
Thanks I’ve got it !!!.  ;D ;D ;D
1 question though the switch is it a push to make or a push to break,  I would like to believe it is momentarily on or off.
Can the circuit be modified to run from 12v supply, and how?
Once a gain thanx
Virus
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
