ck1 Posted April 15, 2006 Report Posted April 15, 2006 Hi Everybody,I am a newbie here. I am looking to make a "giant" VU meter. I took a piece of PVC pipe 3" in diameter and 5 feet tall. I cross-drilled 2" PVC and mounted a 1 watt Luxeon star in the bottom of each tube. Audioguru's sound level meter is exactly what I want, with the microphone input so I don't have to plug it into my stereo. It does not have to be accurate, I just want it to "dance" to the beat. I have attached a picture with the LEDs just hooked to a power supply.What I need now is to adapt Audioguru's circuit to power the large LEDs. They run on 3.84 volts at 350mA. Since the LM3915 has regulated current output for LEDs, I assume I can hook a transistor (PNP I think?) up in place of the LEDs, which will switch the big LEDs on and off. Can someone give me advice on this? Be very specific, I am an electronics novice.ThanksCK1 Quote
audioguru Posted April 15, 2006 Report Posted April 15, 2006 Hi CK,Welcome to our forum. ;DYou will need a power supply cabable of supplying 3.5A for your project. I haven't seen a 9V supply with such a high current so you can make one yourself from a 12V cener-tapped 5A transformer, a 10A pair of rectifiers and a 4700uF filter capacitor.PNP transistors like a 2N4403 can drive your LEDs through a 12 ohm 2W current limiting resistor.. The resistors will get hot and need some air circulation because they will dissipate about 1.3W each. Quote
windoze killa Posted April 17, 2006 Report Posted April 17, 2006 Depending on you power supply and how you wire them PNP will be the wrong type. In a "normal" switch configuration the middle letter of PNP or NPN denotes the polarity of the required power supply. As such a PNP transistor will require a negative voltage on the bae WRT the emitter to switch the transistor on. If you can provide a circuit of how yopu intend to hook it up it would help. Quote
audioguru Posted April 17, 2006 Report Posted April 17, 2006 Connect a PNP 2N4403 transistor to the LM3915 and current limiting resistor and Luxeon LED like this: Quote
windoze killa Posted April 17, 2006 Report Posted April 17, 2006 Exactly what I was trying to say. Well done. That should get him out of the problem. Quote
ck1 Posted April 21, 2006 Author Report Posted April 21, 2006 Thank you very much, I will give it a shot. Quote
ck1 Posted April 21, 2006 Author Report Posted April 21, 2006 AG,I notice you show a 7.8V supply. I neglected to mention that I have a 5V supply I found on Ebay, will that work? How does that change the resistor values?ThanksCK Quote
audioguru Posted April 21, 2006 Report Posted April 21, 2006 Hi CK,I planned using a center-tapped 12V transformer to make 7.8VDC. It doesn't need to be regulated.A 5V supply voltage is too low. There will be hardly any voltage across very low-value current-limiting resistors to allow for differences in the LEDs' voltage and resistor tolerance. Quote
