pearlyred Posted April 30, 2006 Report Posted April 30, 2006 I think the indicator relay on my car is playing up as the flashing keeps pausing/stopping and all the bulbs are working.Have pulled the relay out, just wondering if there's any way i can test things or fix it?Does anyone know much about these? i can see a small IC on there, which I assume must be a timer, but i dont really have a clue. Would this be the most likely part to fail?Some pics of the relay here Any advice on whether this is fixable and how would be great.cheers Quote
ante Posted April 30, 2006 Report Posted April 30, 2006 The contact points looks badly burnt, maybe they stick and course the irregular operation. Quote
steven Posted May 11, 2006 Report Posted May 11, 2006 i use a relay indicater flasher unit for my version scr tester, in the high voltage stuff section and mine dosent have an ic it has electrolytic capacitor and transister in it no ic at all Quote
windoze killa Posted May 15, 2006 Report Posted May 15, 2006 I woukld be looking for a dry joint or a cracked joint. If it has an IC it is probably a solid state device so there is probably no relay and would be working from an SCR or other switching device. Rip the case off and resolder all the joints without over heating them. Or spend $5 and buy a new one. Quote
