Jump to content
Electronics-Lab.com Community
Variable Capacitor
So is that a wire from O to A and then a wire from A to the circuit and a wire from O to the circuit, and dis-regard G all together?
Sorry, I am new to this!
In my mind I see a wire from A to the circuit and G to the circuit gives me 160
O to the circuit and G to the circuit gives me 60
A to O with a wire from A to the circuit and O to the circuit is 220.
Are these correct or just plain wrong?
Thanks again
Link to comment
Share on other sites
Then you have shorted the variable capacitor with the wire.
In my mind I see a wire from A to the circuit and G to the circuit gives me 160.
Yes.
O to the circuit and G to the circuit gives me 60.
Yes.
If you want their total capacitance of 220pF then connect them in parallel. Connect A to O and to the circuit and connect G to ground in the circuit.
Link to comment
Thanks a ton for the response.
Just to double check I am thinking of this correctly:
A wire goes from A to O. Then a wire from O tp the circuit. ( this is connecting them in parrell, or did you mean in series? ). Then a wire from G to the circuit.  This gives me the 220pf?
So I would have only two wires running from the cap to the circuit, not 3, and I would have the 220pf. Is that correct?
Thanks again
PS. Is there a schematic of a variable cap I can find online?  Thanks
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
