bir_alma Posted June 9, 2006 Report Share Posted June 9, 2006 I want to design a solar based water pump as a project. I do not have much problem on the design of the solar part of the design, but on the water pump part. So could you help me how to proced.Thanks in advance. Quote Link to comment Share on other sites More sharing options...
ante Posted June 10, 2006 Report Share Posted June 10, 2006 Hi bir-alma,Welcome to our forum.Can you please try to explain more in detail the pump problem? Quote Link to comment Share on other sites More sharing options...
bir_alma Posted June 13, 2006 Author Report Share Posted June 13, 2006 The problem with the water pump design for me is I do not know the principles of working the water pump,the materials required and how is connected with the dc motr. The type of water pump that i need is well water pump. Quote Link to comment Share on other sites More sharing options...
ante Posted June 13, 2006 Report Share Posted June 13, 2006 Here’s a little something about pumps for you. [attachment deleted by admin] Quote Link to comment Share on other sites More sharing options...
rybitski Posted June 27, 2006 Report Share Posted June 27, 2006 It would be alot easier to buy a pump.How bigg of a pump to you need? How many Gallons per minute and how many feet of over head power do you need? Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted July 8, 2006 Report Share Posted July 8, 2006 I know about Pumps. How many Gallons Per Min or GPM ?If you were just wanting to run a fountain pump off of the sun that would be easy. A 12v solar battery charger with a 12v bilge pump for boats. Quote Link to comment Share on other sites More sharing options...
