Jump to content
Electronics-Lab.com Community
Silicon Chip magazine
MNA
http://rapidshare.de/files/5599689/Silicon.rar.html
:D
6-Channel IR Remote Volume Control - Part 2
10-Channel IR Remote Control Receiver
12-channel Infrared Remote Control
12V Flourescent Lamp Inverter
45-Second Voice Recorder Module
A 2_4GHz High-Power Audio-Video Link
A Digital Thermometer-Thermostat
A Dirt-Cheap, High Current Power Supply
A Low-Cost 50MHz Frequency Meter
A Poor Man's Q Meter
A Programmable Continuity Tester
A Programmable PIC-Powered Timer
A 'Smart' Slave Flash Trigger
A 'Tiptronic-Style' Gear Indicator
A Windows Based EPROM Programmer
A Windows-Based EPROM Programmer - Part 2
Active 3-Way Crossover for Loud Speaker Systems
Adjustable DC-DC Converter For Car
Alternative Power Regulator
Antenna & RF preamp for weather satellites
Appliance Energy Meter, Pt_1
Appliance Energy Meter, Pt_2
Automatic Single-Channel Light Dimmer - Part 2
Balanced Microphone Preamp
Bidirectional Motor Speed Controller
Big-Digit 12-24 Hour Clock
Build A Professional Sports Scoreboard, Pt_ 2
Build A V8 Doorbell
Build A Water Level Indicator
Build An AVR ISP Serial Programmer
Build The Decision Maker
Bulid Your Seismograph
Car Battery Monitor
Carbon Monoxide Alarm
Charger For Deep-Cycle 12V Batteries, Pt 2
Circuit Notebook 3
Circuit Notebook 4
Circuit Notebook 5
Circuit Notebook 6
Circuit Notebook 7
Circuit Notebook -8
Circuit Notebook -9
Circuit Notebook -10
Circuit Notebook -12
Circuit Notebook
Circuit Notebook-
Circuit Notebook=
Compact 0-80A Automotive Ammeter
Component video to RGB converter
Controlled Automatic Table Lamp Dimmer
Courtesy Light Delay For Cars
Digital Instrument Display for Cars - Part 1
Digital Instrument Display for Cars - Part 2
Direct Conversion Receiver For Radio Amateurs - Part 1
Direct Conversion Receiver For Radio Amateurs - Part 2
D-I-Y remote control for a model train layout
Dr Video Mk_2 An Even Better Video Stabiliser
Driving Light and Accessory Protector for Cars
ESR Meter 1-Mk_2
ESR meter hints
ESR Meter Mk_2
Fridge-Door Open Alarm
Getting into WiFi, Pt_ 3
High-efficiency power supply For 1W Luxeon Star LEDs
Home-Brew Weatherproof 2_4GHz WiFi Antennas
Improved Speed Controller for Universal Motors
Inductance & Q-Factor Meter, Pt_1
Inductance & Q-Factor Meter, Pt_2
IR Remote Control Checker
keyb18xa_bas-
Lapel microphone adaptor for PA systems
Lead-Acid Battery Zapper
Level meter for home theatre systems
Linear Supply For Luxeon 1W Star LEDs
Long-Range 4-Channel UHF Remote Control
Long-range 16-channel Remote Control System
Magazine for Hobby Electronics, Computing, Kits and Projects
MIDI Theremin, Part 2
More Fun With The PICAXE - Part 3 Heartbeat Simulator
More Fun With The PICAXE - Part 4 Motor Controller
More Fun With The PICAXE - Part 5 A Chookhouse Door Controller
More Fun With the PICAXE A Shop Door Minder
MUDLARK A205 Valve Stereo Amplifier
Not Another CFL Inverter
OLED Displays Better Than Plasma Or LCD
One-chip Transceivers for easy UHF Data Communications
photos
PIC Controlled 32-LED Knightrider
Picaxe-18X 4-channel datalogger
PICAXE Application Special PICAXE 08 Port Expansion
PICAXE Application Special PICAXE Telephone
PICAXE Infrared Remote Control
PICAXE- Part 9 Keyboards 101
PICAXE The New Millennium 555
PICAXE(s) -are these chips the New Millenium 555
Poor Man's Metal Locator
Portable PIC Programmer
PortaPAL Public Address System - Part 2
Printer Port Hardware Simulator
Programmable Flexitimer
Real Yagi Antenna For UHF CB
Remote Volume Control For the Ultra-LD Amplifier
RFID Security Module
RFID Tags - How They Work
Rolling Code 4-Channel UHF Remote Control
RTTY Modulator
Serial Stepper Motor Controller
Shorted Turns Tester
Shut That Mutt
Silicon Chip 1
Silicon Chip 2
Silicon Chip 3
Silicon Chip 5
Silicon Chip 6
Silicon Chip 7
Silicon Chip 8
Silicon Chip Electronics 4
Silicon Chip Online - A Lap Counter For Swimming Pools
Silicon Chip Online - Low Cost 1HZ 10MHz Function Generator
Simon Says
Single-Channel Light Dimmer - Part 2-
Smart Card Reader and Programmer
SMS Controller, Part 2
Solar Powered Wireless Weather Station
Starpower - A Switching Supply For Luxeon Star LEDs
Sunset Switch
SuperCharger Addendum
SuperCharger For NiCd & NiMH Batteries - Part 2
Telephone Dialler For Burglar Alarms
Telephone Headset Adaptor
Test Your Reaction Times With A Digital Reaction Timer
The Battery Guardian
The Coolmaster Fridge-Freezer Temperature Controller
The Mesmeriser
The Micromitter Stereo FM Transmitter  :D
The PICAXE Part 6 - Data Communications
The PICAXE Part 8 - A Datalogger and Sending it to Sleep
Three Do-It-Yourself PIC Programmer Kits
time lapse camera
Updating the PIC Programmer and Checkerboard
USB Power Injector
USB-Controlled Power Switch
Versatile Micropower Battery Protector
Versatile Multi-Mode Timer
VHF Receiver For Weather Satellites
Video Enhancer & Y-C Separator
Video Formats Why Bother
Video-Audio Booster For Home Theatre Systems
Whistle & Point  Cable Tracer
White LED Driver
WiFry Cooking up 2_4 GHz Antennas
1-A Programmable Continuity Tester
1-SMS Controller Pt_1
4 Digit Crystal-Controlled Timing Module
4-Minute Shower Timer
Link to comment
Share on other sites
not complaining, but when you save a html page you should include the folder with it, it contains the pictures. there are no schematics to go along with the text! anyways most of this is free at the website, if you check it out read the repair shop guys storys, he figures things out that sometimes airn't so obvious (the terminology he use is a little weird too).
Link to comment
Hi Mugsby,
I'm sorry but I haven't uploaded it!I have downloaded it :) , I got this link from  other source......
You can see the pictures if you left click on the boxes which r there for the pictures.......I did this and got the schematics........
free! whenever I tried to see the projects at silicon chip,I was asked to pay for it.....some other members also say that they can get it free but I don't know why I can't.......
Repair shop guys storys????????????
Link to comment
Hi rigdoctor99,
Mugsby was replying to me.....
Don't ask me doctor,my internet speed is too slow.....but I'll try.....
the web is full of rapidshare stuff......it's a great loss to u......my advice is that try to solve the problem with rapidshare.....
Link to comment
being rude to people isn't going to help you, thats for sure....
ok i'm going to explain this to you, rapidshare lets you download up 30megs at a time with the free option based on you ip address, then you have to wait an hour and a half before you can do it again. if you use one of the paid plans you don't have to wait, they are providing a usefull service free or paid and i won't look a gift horse in the mouth, know what i'm saying?
if you know someone you can access an ftp with most of the books free.
Link to comment
Hi doctor,
In case u don't know....when u go to the link ,a page will come up where u have to choose one of te two options either a premium account or a FREE option...click on the FREE button and then they will ask u to enter the 3 digit code(sometimes only 1 digit also).....then u can click on the download button on the right......
download resumers/accelerators are not supported by rapidshare......
and the rest Mugsby have told u......
Link to comment
Hi doctor,
when I try to download two files at a time from rapidshare, I get the message"Your IP-address is already downloading a file. You have to wait until it is finished.
Premium-accounts can download many files at the same time. Get your own premium-account now. Instant download-access"
otherwise it works fine......
will search for the error you receive.....
Link to comment
u can try this if u like(I haven't tried it...I searched it for u)....hope this helps u......
http://www.liewcf.com/blog/archives/2006/01/crack-rapidshare-wait-time-limit/
tell me it worked or not....
hmm...I think that's something different....Will try to discover some solution...
Link to comment
  Thanks for the links MNA, but I am an electronics tech who has very little knowledge of these download things you posted.......  I am of the mind that if I click something and it does what I want then all well and good, but if I have to play about to get it to do what I want I dont use it............
I have also very limited knowledge of these things....but trying to expand it now.....That's why I haven't checked those links myself....may be other members tell u their experience or give a better suggestion......
  I am almost 50years old and learned my skills without the aid of computers.  ::) ;D
first of all , am sorry to call u by your nick.....Secondly,for us internet is becoming a good source of education if it is used in the correct way....
Link to comment
  • 11 months later...
Hello everyone
i have lost this file...somehow it got deleted from my hard disk..... if any of u have it then please post it....
upload it at any of the file sharing sites as i think uploading it here is not allowed(Rules)......
Link to comment
the difference betweenthe two files is the filesize...... the one i had before doesn't have any pictures which reduced the size...... downloading such a big file which u gave is impossible for me....... if u have the above file(withoiut pictures ) then please post.....
thanx
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
