PCB Design
Can someone design a PCB for this schematic?? (The dotted cap. is ment to be a 10uF elec. with a dual pot. in series (one for each amp) and to be connected to pin 1 not ground and the 2.5M is the volume) The amp type i'll be using is the LM380N. Thanks
This seems a very simple design. Why not have a go at it yourself? There are plenty of progs out there to help you.
hello thunder
  There is a good eagle tutorial on the eagle web site plus I think I posted one in pdf format someware on this site. You can search this site for it.
                                                  have fun
                                                    gogo
Zak, it looks good. Nice ground plane and the traces look like they are far enough apart so that they will not cause interference.
I was not able to check your schematic against the board layout, but the layout itself looks well done.
MP
