Jump to content
Electronics-Lab.com Community
Difference b/w Electrate and Condensor mikes
I want to know diff b/w an electrate & cond mike.
If you spelled "electret" correctly then you could have looked at its operation in Google.
The electret material holds a high voltage charge which allows the mic to work.
A condenser mic doesn't have the charge so needs an external high voltage power supply (48V) to work.
Many people wrongly call an electret mic a condenser mic.
An electret mic must be connected with the correct polarity.
which one is more sensetive
They have about the same low sensitivity.
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
