ta03 0 Posted July 13, 2005 Report Share Posted July 13, 2005 Both transistors are from toshiba.Oh well...I will buy new ones. ::) Quote Link to post Share on other sites
audioguru 36 Posted July 13, 2005 Report Share Posted July 13, 2005 Hi Maksar,That heatsink extrusion mentioned a length of 87 inches so I thought it is sold that long.I don't know the calculation for a different length than 3 inches, when you double it then the thermal resistance certainly doesn't become half.A thermal resistance of 0.2 would be great with a fan and you can add 0.7 for a transistor insulator. Then at 57W in a transistor and a 30 degrees C ambient its junction temp would be 167 degrees C.Without a transistor insulator and without a fan, the junction temp would be 144 degrees C.You'll have to calculate the 5A version separately but the temp will be only a little higher.There isn't a requirement to limit the metal transistor's junction temp to only 100 degrees C because its max rating is 200 degrees C.2 heatsinks are required for the 3A project, and 3 for the 5A project.I think the fins on the heatsink must be vertical to allow for convection cooling. Quote Link to post Share on other sites
audioguru 36 Posted July 13, 2005 Report Share Posted July 13, 2005 Hi Zeppelin,Common opamps are designed for a 30V supply, 36V absolute max. I posted some with 44V absolute max.If you want this project to produce a well-regulated 30V at full load then its positive supply will be more than 38V at full load and about 44V without a load and when the transformer's voltage increases without a load. Add some more voltage when your AC or refrigerator shuts off. Then add the 5.6V negative supply and look for another opamp with a 54V supply rating. The OPA445AP is the only one I could find. It is $9.50US today at Newarkinone and Digikey if you buy only a few, less cost if you buy 25 or more. ;D Quote Link to post Share on other sites
audioguru 36 Posted July 13, 2005 Report Share Posted July 13, 2005 Hi Zeppelin,The original circuit supplies up to 41V (with no load) to its opamps that have an absolute max supply voltage of 36V. If you use cheap opamps with a 44V supply rating like the MC34071 or TLE2141 then they will be happy. Then the project might be able to supply 2.5A at up to about 25V, if its little Q2 and its single Q4 don't melt.Replace the original 2N2219 for Q2 with a cheap but powerful TIP31A and the project will be a bargain. ;D Quote Link to post Share on other sites
NYghost 0 Posted July 15, 2005 Report Share Posted July 15, 2005 Hi everybody...I have a little question, can I replace the 2N2219 (Q2) by a 2N2222A ?Or is there anyone transistor who can work in this list (list of my shop) 2N1613 (=2N1711) 0,40 € 16,14 FB 2,62 FF 2N2222A 0,30 € 12,10 FB 1,97 FF 2N2646 1,20 € 48,41 FB 7,87 FF 2N2904 0,40 € 16,14 FB 2,62 FF 2N2905 1,00 € 40,34 FB 6,56 FF 2N2907 0,30 € 12,10 FB 1,97 FF 2N2907AP 0,30 € 12,10 FB 1,97 FF 2N3055 1,50 € 60,51 FB 9,84 FF 2N3773 6,50 € 262,21 FB 42,64 FF 2N3819 0,70 € 28,24 FB 4,59 FF 2N3904 0,25 € 10,08 FB 1,64 FF 2N3906 0,25 € 10,08 FB 1,64 FF 2N4403 0,30 € 12,10 FB 1,97 FF Big thanx in advance ;)See you soon :)++ Quote Link to post Share on other sites
audioguru 36 Posted July 15, 2005 Report Share Posted July 15, 2005 Hi NY,Welcome to our forum. ;DIn this post we have talked about the 2N2219 getting too hot. You want to replace it with a tiny 2N2222A? It will melt. :(Your transistors are all different unsuitable types. Why not just purchase a cheap TIP31A that is recommended? Quote Link to post Share on other sites
audioguru 36 Posted July 17, 2005 Report Share Posted July 17, 2005 Hi Zeppelin,I keep getting notification of replies from you that don't exist and get instant messages from you that I can't reply to, about the high cost of parts for this project. This is what I recommend for a 3A supply:0-30V_Mod_parts_list.txt Quote Link to post Share on other sites
audioguru 36 Posted July 18, 2005 Report Share Posted July 18, 2005 Yeah, this site has problems. It was down for hours then came back and gave me a bunch of phoney e-mails about people replying to my posts a few days ago. But the new e-mails are copies of ones I received a few days ago. Quote Link to post Share on other sites
Vedran 0 Posted July 19, 2005 Report Share Posted July 19, 2005 I have old transformer with a secondary winding rated at 24 V / 1.2 A, or you can say 20VA.Can I use this one with this project with no changes in parts values? Thanks Quote Link to post Share on other sites
NYghost 0 Posted July 19, 2005 Report Share Posted July 19, 2005 Thx for the reply audioguru ;) !I confirm that my shop have TIP31A in stock... Thanks and see you soon :) Quote Link to post Share on other sites
Vedran 0 Posted July 19, 2005 Report Share Posted July 19, 2005 I have old transformer with a secondary winding rated at 24 V / 1.2 A, or you can say 20VA.Can I use this one with this project with no changes in parts values? ThanksI can also buy from my friend transformer 2x12 V that can handle 8,33A...Maybe i should put this one. I think this one will heat less and buzz less than smaller one??What do you think?Thanks! Quote Link to post Share on other sites
audioguru 36 Posted July 19, 2005 Report Share Posted July 19, 2005 Hi Vedran,The transformer will be seriously overloaded unless you change the value of R7 to 2.2 ohms/2W to limit the project's max output current to about 0.6A.Change R11 to 39k to limit the max output voltage to about 27V because the output will have a high ripple when it is set to voltages above about 25V with its full 0.6A current.The project's original little 2N2219 can be used for Q2 and a single 2N3055 can be used for Q4 because they won't overheat.I think the transformer will produce 28VAC or more when the project has a low load current with your transformer. Therefore the opamps will have a total supply of about 44V or more and I recommend using OPA445AP high-supply-voltage opamps. ;DWith the 8.33A transformer, you can build the 5A option for this supply and change R11 to 39k to limit its output voltage to about 27V. Quote Link to post Share on other sites
Vedran 0 Posted July 20, 2005 Report Share Posted July 20, 2005 With the 8.33A transformer, you can build the 5A option for this supply and change R11 to 39k to limit its output voltage to about 27V. Quote Link to post Share on other sites
audioguru 36 Posted July 20, 2005 Report Share Posted July 20, 2005 Hi Vedran,We discussed the necessary changes to make this project produce 5A in this topic:http://www.electronics-lab.com/forum/index.php?topic=196.0It needs three 2N3055 output transistors with emitter resistors and each transistor needs its own pretty big heatsink. The project also needs a powerful heatsinked rectifier bridge module, and a huge filter cap.A few resistors have their power rating increased and R7 must be 0.27 ohms.With your lower voltage from the transformer you should keep the value of R14 at 1.5k.Yes, also change R11 to 39k.Kain made a schematic and pcb for the 3A version here:s_PSU.pdf Quote Link to post Share on other sites
Vedran 0 Posted July 20, 2005 Report Share Posted July 20, 2005 Making PCB is a bit problem for me, and making two sided even bigger problem , so I will have to satisfy with 3A version. If anyone has one PCB he don't need or can easily made one extra PM me please.Thanks! Quote Link to post Share on other sites
audioguru 36 Posted July 20, 2005 Report Share Posted July 20, 2005 Hi Vedran,The original pcb will work for the 5A version with C1, the rectifier bridge module and R7 mounted externally. A few other resistors will be a tight fit and must be stood-off the pcb. Q2 will need its leads crossed or it can also be mounted externally. ;D Quote Link to post Share on other sites
Vedran 0 Posted July 20, 2005 Report Share Posted July 20, 2005 Thanks audioguru, I will try, and post here results when I am done! Bye Quote Link to post Share on other sites
ta03 0 Posted July 21, 2005 Report Share Posted July 21, 2005 Hi all!I am back from my vacations!One more question: Can i put 3 or 4 paralleled 2n3055 transistors just to be on the safe side? Quote Link to post Share on other sites
audioguru 36 Posted July 21, 2005 Report Share Posted July 21, 2005 Hi Ta,Welcome back. I hope you had a nice vacation.Now that I am retired, every day is a holiday and sometimes I have a nice vacation too. ;DSure, use 3 or 4 2N3055 transistors to divide the heat dissipation among them. Use a separate heatsink for each one.One member had trouble matching them even though he used 0.1 ohm emitter resistors.For a 3A supply, maybe 1 ohm/2W or 5W emitter resistors should be used for a better match. Quote Link to post Share on other sites
ta03 0 Posted July 23, 2005 Report Share Posted July 23, 2005 Yes,i had a wonderfull vacation thank you!I envy you audioguru.I am still a student and i have 50 years in order to become retired. I finally used 3 of them with 0.1ohm emmiter resistor at 2 of them and 0.2ohm at the third one in order to match them.What i did is ok?With a fan blowing them they dont become hot at all.Another discovery: I have 4A max output :o Quote Link to post Share on other sites
audioguru 36 Posted July 23, 2005 Report Share Posted July 23, 2005 Hi TA,It's good to hear that your vacation was wonderful. ;DIt is fine to change the emitter resistors to balance the output transistors.If you want to feel some heat, turn up the current regulator and short the output. That will be when the output transistors should be matched. Almost the same thing will happen if you turn up the current regulator and turn down the voltage regulator to drive a low-voltage high-current load. ;D Quote Link to post Share on other sites
ta03 0 Posted July 23, 2005 Report Share Posted July 23, 2005 I tried with a 2.7ohm 200W dummy load.I set 3A output.All transistors were quite cool.I am afraid to short the output.Another discovery: From one transistor passed 1.3A,from the other 1,1A and from the third(with 0.2ohm emmiter resistor) 0.6A.My mistake is that i measured the third transistor's resistor and found the voltage drop almost the same with the other 2,forgeting that it was not 0.1 ohm. :-\ :-\ :-\ .How much current can pass from one transistor without damage? Quote Link to post Share on other sites
audioguru 36 Posted July 24, 2005 Report Share Posted July 24, 2005 How much current can pass from one transistor without damage?If the output is shorted of your project with its low unregulated supply voltage of only 31V, the internal chip of a 2N3055 transistor will operate with no margin for safety at its absolute max temperature of 200 degrees C, with an enormous heatsink of infinite size, with a very high velocity fan blowing away all heat so its case doesn't exceed 25 degrees C, at a current of only 3.7A (115W of heat with your 31V supply). Quote Link to post Share on other sites
msilveira 0 Posted July 29, 2005 Report Share Posted July 29, 2005 Audioguru, give us some hints about this, please :) :Hello,I like your web site.I'm interrested about 0-30 VDC STABILIZED POWER SUPPLY WITH CURRENT CONTROL 0.002-3 A and have couple of questions.Is it possible to increase output current to 5 Amps ? (adding 2N3055 and changinging some component values)Can I built 2 similary power supply and use it in serial mode 0-60 V or in parallel mode to get more current 0-10 Amps or use it like dual power supply +/-30 V ?Thank youTomislav,Croatia ???Hi all, I'm new to the EL forums, but not new to the website, nice stuff here :DAs Tom said, I'd be interested on building a bipolar PSU unit with the capabilities of this project. I still have to read all the threads, I have read something about fixing the original design among the posts(so many!)...Right now, I have a 3-wire trafo, 28+28 (really 28+0+28) over my table... but it's just 1A...I was wondering: If I found a 28+0+28 (or with a little higher voltage), what current should it be: 3A or 6A?What changes should it have to operate bipolarity?You know, many experiments requires bipolar feeds...I would be interested in adding parallel LM7(8/9)0(5/6/9/12/whatever)s or LM3(1/3)7s for extra fixed voltages...I still have much left to learn indeed... but for now, my knowledge allows me to provide good shcematics/pcb design, maybe we could open another topic: "[glow=red,2,300]30-0-30 VDC BIPOLAR STABILIZED PSU[/glow]" ??? Then we could adapt the changes of the 5A topic to the bipolar one to become a bipolar 5A PSU ???All that is left for my improvement idea is a button to make it speak the current and voltage instead of displaying with the digital meter presented ;D (Just joking!)Thanks,Mauricio Quote Link to post Share on other sites
Tedy 0 Posted July 29, 2005 Report Share Posted July 29, 2005 Hi!Me again :)I got 3 pieces of OPA445AP from TI as free samples ;)And I wonder on what I should be careful, because I dont want them burn or damaged.According to datasheet of OPA445 I should use 100k trimpot, is that correct? Quote Link to post Share on other sites
