Jump to content
Electronics-Lab.com Community
Posted
This original project does not get hot in Italy?
1) The transformer is rated for 24VAC/3A which is only 72VA.
The peak voltage is 34V and if the project delivers 3ADC then the transformer supplies 102VA and is 142% overloaded. Sure it gets hot.
2) The 2N3055 transistor can dissipate about 70W if it has a huge heatsink and does not have an insulator.
If the output current is set to 3A and the output voltage is set to a low voltage or is shorted then the 2N3055 transistor dissipates 96W. It is 137% overloaded. Sure it gets hot.
3) The 2N3055 transistor has a minimum current gain of 25 when it conducts 3A. Therefore its base current is a max of 120mA.
If the output current is set to 3A and the output voltage is set to a low voltage or is shorted then the little 2N2219 transistor dissipates 3.72W. Its max allowed dissipation is only 2.5W when it has a "perfect" heatsink. Its clip-on heatsink is far from being perfect then the transistor has its max allowed internal temperature when it dissipates only 1.8W. It is 207% overloaded. Sure it gets hot.
4) People here reported that the rectifier diodes char (blacken) the pcb. They must be pretty hot.
The improved circuit can use the original pcb:
1) Mount the rectifier bridge module on the metal chassis.
2) Mount Q2 on the chassis or on the heatsink.
3) Strap the main filter capacitor beside the pcb.
4) Stand up some of the larger resistors.
Posted
I'm from Lithuania :)
We mostly use not new details. transformer mostly been from old radios or tv.
O about tranzistors........ i dont know. some people said that everything is okey
Posted
Subodhthok,
It is a simple circuit with opamps and transistors. When you learn about opamps and transistors then you will understand the function of each and every component.
The Articles section of this website has tutorials on opamps and transistors.
Fluffy,
My recommended parts list for this project has been attached many times and has not changed for more than one year. Here it is again:
0-30V_Mod_parts_list.txt
Posted
Hi again.
I've build the modified circuit. Everything seems to work. The voltage goes up to 34.5V and the current to 3.8A.
The op-amps U1 and U2 get very hot with no load, especially U1. I measured the voltage at pin7=46V.
Also I used two 2n3055 transistors with 0.33R emitter resistors but one of the transistors gets hotter than the other one. What can I do to fix the problem?
Also when I turn the current potentiometer half way the current increases to 0.5A. So when P2 is half turned the current is not half its maximum value. I'm not sure if this is a problem.
Thank you for the help.
Posted
Hi again.
Good, it works.
Trimpots can be added in series with the voltage and current setting pots to reduce their max outputs to 30.0V and 3.0A. Then the trimpots can be measured and fixed resistors can be installed.
The max operating current of the OPA445AP opamp is only 4.7mA x 46V=216mw. Its load is (46V - 11.2V) x 5.6mA= 195mW. The total power dissipation is a max of 411mW and its max is 1000mW. It will be pretty warm but it is fine.
It is a little high but it is fine.
A 30VAC/4.3A transformer will be about 31.5VAC without a load. Then its peak voltage is 44.5V and the rectifier bridge drops it to 43V.
The transistors are all different. That is why the emitter resistors are used to equalize their current gains. Yours must be very different. Use a 0.22 ohms emitter resistor for the coolest one then it will heat more. 8)
I think the action of the current-setting pot is supposed to be linear, so half rotation is 1.5A, but maybe not. Try replacing the pot.
Posted
I've been reading this thread and I see that there has been a significant amount of problems with this project heating up, with the schematic that is posted in the projects. I also see that audioguru has provided an updated parts list can some tell me why the person who maintains the projects doesnt update the parts list with the scematic  :D Just curious as to how things work ??? also If i use the new parts list is the schematic still the same
Thank you
Posted
Hi Steve,
The project is a kit. It overheats and does not have 30V/3A output. I don't know what the kit maker does about complaints to them about the kit.
We leave the original project in case somebody has built it and for us to talk about it. If somebody builds the improved version and updates the schematic then it might be made into a new project.
The improved circuit has the same pcb as the original except a few parts values are changed. A few parts are bigger but can be stood up, and Q2 needs to be mounted away from the pcb on a heatsink or its pins will need to be twisted around. A second 2N3055 output transistor was added to share the heat and emitter resistors are used for the output transistors to equalize their different current gains.
Posted
how can i modify this circuit to 0 to 50 v dc supply
Re-calculate and replace every part in it.
and also for 0 to 30 v 10A
If it is set to 10A and the output voltage is set low or it is shorted then the output transistors must dissipate 420W. Use 6 output transistors on huge heatsinks with fans, use 3 driver transistors, add a pre-driver transistor and make many resistors larger.
A larger transformer, larger main filter capacitor and larger rectifier bridge will be needed.
It will cost a small fortune.
Posted
Hi.
I have just built the PSU but surprise-surprise it does not work. Output voltage of the PSU is constantly 33V. Voltage between pin4 and pin6 of u1 is chancing from 0 to 9.9V when turning voltage pot.
I am using UA741 opamps. [+-22V]
Voltage over pins 4 and 7 is 38V on U3 and U2. On U1 it's 33V.
Chanced RV1 to 10k, short circuited R10[Like in the 741's datasheet]
What purpose has D10? Doesn't it just feeds all the output voltage directly to the base of Q2? R15 is heating....voltage on it is ~33V. When I remove all opamps the output voltage stays up. When I remove Q1 or both(!) of it's base resistors then output voltage drops to zero.
-Eggy
Posted
Hi Eggy,
Welcome to our forum. ;D
Q1 is not supposed to make the output voltage high. It is supposed to make the output voltage zero when the project is turned off. Q1 does not have a positive supply.
Maybe the base of Q1 or one of its base resistors is shorted to the positive supply. Then Q1 will turn on Q2 and Q4 through its forward-biased base-collector diode.
D10 is normally reverse-biased. It quickly discharges the output capacitor C7 when the project is turned off to avoid exceeding the max reverse voltage rating (about 6V) of the emitter-base of Q2.
Posted
I know that Q1 is for bringing output voltage lo. Base of Q1 is not short circuited to positive supply, only through r13 which is not connected at the moment.
Let's assume that I remove Q1 temporarely, I loose thats protective idea in the circuit, BUT i should be able to chance output voltage, right? What voltage should be on pin6 of U2?
Posted
Hi Eggy,
If you remove Q1 then the circuit should work properly. Q1 quickly reduces the output voltage to zero when the project is tirned off, so that the output voltage doesn't rise.
Pin 6 of U2 should be about 1.4V higher than the output voltage without a load.
U2 and the output transistors have a voltage gain of 3.07 and amplify the voltage from pot P1.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
