Jump to content
Electronics-Lab.com Community
Irda Help
PrivateTester
I don't have a schematic but I can give you a hint.
The modules usually transmit a 38-40khz signal.
the transmitter is just an IR led and the receiver is a IR sensitive Photo transistor.
An amp and a Phase Locked Loop pick up the signal from the transmitter.
The data being sent is transmitted at a very low frequency.  If you send on/off
pulses too fast you will begin having trouble with the carrier freq (38-40khz)
When set up correctly, a high signal into the transmitter will begin sending the high freq IR signal through the LED. The receiver will pick it up and output a high signal because the PLL matches the signal being sent.
Turn off the transmitter and the output of the receiver also goes low.
Hope that helps.
-Mike
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
