sayadlou Posted July 18, 2006 Report Share Posted July 18, 2006 hi every bodyI need some information about :FPGA ,how to program it and its programer Quote Link to comment Share on other sites More sharing options...
Theatronics Posted July 18, 2006 Report Share Posted July 18, 2006 FPGA means (Flat Pack Grid Array)This is a package type, not a chip type.Programing will depend on what electronics arein the FPGA.Do you have a part number?-Mike Quote Link to comment Share on other sites More sharing options...
Theatronics Posted July 18, 2006 Report Share Posted July 18, 2006 SORRY!See what happens if you don't get your morning caffene!I thought that you were asking about FBGA (Ball Grid Arrays)(Field Programmable GATE arrays)Ohhhh. well that’s something different.They usually require a (Compiler) that will take a logic formula or some even use graphical diagrams, and convert it into a series of signals that (open or close) connections between prewired gates in the chip)Depending on the device used, there the programming interface can range from an In-Circuit programming, A standard EEprom Burner, or a custom interface.I have used devices from this co before:http://www.xilinx.com/Sorry about the confusion-Mike Quote Link to comment Share on other sites More sharing options...
