Jump to content
Electronics-Lab.com Community
6V 5A PSU problem.
I have a question here...i currently doing a power supply which is capable to supply max of 6V and 5A of output. the PSU is a digital PSU with microcontroller and LCD interface which means that the output can be adjusted to any desired value.
the problem is the output ripple noise of the PSU is not really satisfying. Maybe can apply some filter circuit on the output terminal of the PSU. Am i rite? But my question is how to choose the right capacitor type and value? I try with a 470uf electrolytic capacitor but the problem is it causing slower stepping down the output voltage, let's say from 6V to 1V (in fact it shd be instantaneous). Any solution to that?
All helps and advices are highly appreciated..thanks 1st.
Link to comment
Share on other sites
Your PSU probably has a switching regulator. Switching regulators have ripple noise on their output due to the way they operate.
That's why I like and use linear regulators that don't have switching ripple noise.
Some PSU's have a switching pre-regulator for low heating, followed by a tracking linear regulator for low noise.
Link to comment
Technically, all switch mode converters require a load (especially converters that run in the continuous conduction mode). Voltage mode converters are even worse in regards to min load levels because of the right halfplane zero in the transfer function.
Specifically for a Cuk, I don't know. That converter topology has been covered by patents for many years, I'm not aware of anyone offering it as a off the shelf technology for standard offerings. For the most part, people just stay away. I did hear that Dr Cuk left Cal Tech and I'm not sure who holds the rights to that technology now.
Just a guess, but I think with typical values L&C, the resonance frequency would be way outside the bandwidth of the converter, and in all likelihood there is enough R around to kill the Q.
I guess not....
Link to comment
thanks for the reply at 1st...
well...my PSU actually nothing but juz consists of a transformer, brigde rectifier and +15/-15 voltage regulator for the op amp. so i guess there isn't any switching regulator in my PSU.
as wat i stated early...the ripple noise can be reduced to <2mV by applying filter capacitor at the 2 output terminal of the PSU. the problem is i not sure the exact value of the capacitor and type to further reduces the ripple.
another problem of applying filter cap at output caused voltage to drop during full load. I cant figure out wat causing the voltage drop.
Furthermore, i dunno shd i use the LC filter, RC filter or etc methods.
thanks and regards
Link to comment
Is the ripple at a low frequency or at a high frequency?
The sensitivity to mains supply ripple for a cheap old opamp is a max of 150uV at the output for each volt of supply ripple. So maybe your ripple problem is caused by poor filtering of the opamp's input signal or lack of signal shielding.
Adding a filter capacitor across the output of a supply doesn't cause the voltage to drop if the capacitor doesn't draw DC current. Your voltmeter might be resonding to the peak voltage of the ripple.
Link to comment
The biggest source of ripple is from an inadequate reservoir capacitor between the bridge recifier and the regulator. Make that bigger, and you reduce the ripple at the regulator's input, and the regulator's ripple rejection isn't stretched so far.
Assuming you are drawing 1A from the supply's output, A 1000uF capacitor will experience a ripple of roughly 8V, which must be rejected by the regulator - hard work by any account. Double the capacitance, and you halve the ripple. Under those same conditions, 10000uF will therefore reduce the ripple down to less than 1V, which will result in less ripple at the regulator's output.
Keep in mind that the drop-out voltage of the regulator will determine the minimum input voltage that it can properly regulate. The LM317 for example needs an input which is at least 2.5V higher than it's output. So, to get it to reliably output 6V it must have an input voltage which never drops below 8.5V. If the input ripple (across the reservoir capacitor) is too large, that voltage may drop below 8.5V, and since the regulator may then fail to regulate, it will appear at the output as 100Hz (UK) or 120Hz (US) ripple.
If this is not the problem, then how about passing the existing output through another regulator (two stage regulation, I suppose you would call it). Since the ripple at the input of the second regulator is so small, the output should be pretty well flat. The problem with this is again the drop-out voltage of the regulators. You'd need to ensure that each regulator's input is at least a couple of volts higher than its output, typically.
It doesn't make sense to put large capacitors at the output of a linear regulator, for the reason you have observed, and because most circuits don't sink current in huge spikes. When circuits do do that it's better to position the capactior electrically close to the current sinking component itself.
Link to comment
to ante sorry if i posted the thread in a wrong section  :P
well actually the 6V 5A is just a single power supply output, in facts, my PSU consists of +25V 1A and -25V 1A of output as well. Since now in the troubleshooting stage, i dun intend to mess up all the part as it complicated the situation. Further, the +25V/-25V supply is separated with the 6V supply.
After the transformer is the bridge rectifier, so there isn't any regulator for the AC to DC voltage. the only regulator circuit i have is the LM7815 and LM7915 for the op amp. the output is control by 2 power transistor based on the control signal from the MCU.
to audioguru, i cant get the freq of the signal from the scope as the scope indicating several MHz. Is that possible? I think something wrong with the reading or scope setup. Even the ripple noise rms of the scope is different from the meter reading. the op amp i used is LF412 from NS or TI.
Link to comment
hi..i noticed that my power source (24-0-24 rating transformer connected to full wave bridge rectifier and filter out by 2x4700uF, 1000uF, 0.1uF and 5.6K resistor all in parallel) having a ripple noise of around 4mV-8mV.
Any idea to further reduce the ripple noise? and hopfully can reduce my overall PSU ripple.
Any formula to calculate the ideal cap value?
thks and regards.
Link to comment
  • 2 weeks later...
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
