Jump to content
Electronics-Lab.com Community
Tank ckt
shahzad-h
At resonsance, the impedance approches infinity (this of course is impossible... there are always circuit paracitics).
From the WWW...
The solution to the circuit (which is a second order differential equation) is
i(t) = Ae ^+ jωt + Be ^− jωt
Considering the initial conditions, solve for A and B.
Because there is a complex exponential (thats the "j" part), the solution represents a sinusoidal alternating current.
Link to comment
Share on other sites
  • 2 weeks later...
When calculating a tank, does the high impdeance differ if Xc=Xl=50 ohms from Xc=Xl=100 ohms?
When you connect the tank at the collector of a transistor, at DC the collector is at the supply voltage. When you apply the signal, does the peak hit the supply voltage, then go down from there with the size of the ouput signal? In other words, at what DC does the signal hover?
Link to comment
Hi Kevin,
Welcome back. ;D
The impedance of a tank circuit at resonance is determined by its Q. Usually it is the inductor's resistance that reduces the tank's Q. Therefore an inductor with a lower reactance would have a lower resistance then the tank would have a higher Q and a higher impedance, but with it the bandwidth is reduced.
I haven't looked for many years, but when the DC collector voltage averages at the supply voltage because the resistance of the inductor is very low, then I think the signal voltage at the collector varies above and below the supply voltage.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
