Jump to content
Electronics-Lab.com Community
Current monitor/sensor
  • Replies 105
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Yes, but why this happening when I try to discharge battery through 0.5E resistor, current is controlled with software regulated PWM output, is this signal appear because OP oscillate via feedback??
I just wondering how to always provide DC signal to load resistor to ensure that always flow also dc current through system.
Link to comment
Share on other sites
Thicker ground wire?? Where exactly??
Circuit is very simple to understand but i have bad dreams about this unstable working:-\^-^
So i made some onother measurements with scope and i figured out that when i put bigger resistor in rc filter, for example 1ME (1ME and 100nF) thern i have small smaller dc signal but stable under discharge process. Problem is to sensing current via shund to atmega adc, resaults is unstable, picture belows shows signal on mosfet gates:
20160225_180107.thumb.jpg.dcbe9da2f53a81
Voltage is unstable from OP output (scope settings is 1V p-p), so that is because unstable current flow from battery.
Onother interesting thing happening on circuit, when i put scope ground on battery ground there is signal like in picture from post before (charging and discharging capacitor), when i put scope gnd to gnd of OP, there is dc signal on current RC low pass filter also with smaller resistor - 100kE+100nF like before!!
the same thing happenig when put scope to Vcc pin of atmega MCU, signal is like in picture below, off course when i start discharge battery:
20160225_171944.thumb.jpg.832b89a0e777e0
Link to comment
With spacing between battery wire (+ and - cable), signal is increasing it's shape like above, when wiring of battery so close together ther is just some little spikes appear on signal how can i avoid this problem, how can i get dc signal on discharging resistor while battery being discharged.
Link to comment
  • 2 weeks later...
  • 1 month later...
I placed thicker wire in some ground places in order to avoid voltage drop as you said above and also put the thicker + and - connection wire for battery connection and problem solved when discharged current to above 2A is flowing, but when increasing current using PWM modulation as described above (increasing duty cycle) signal starts oscillating (picture from scope - some kind of charging capacitor).
So do i have improve ground further to decrease voltage drop??
All works fine but only because of oscillating i have wrong adc reading and i need to use adc averaging but also using this result not precise as i wanted to be!
Link to comment
Your ground wire is too thin so it acts like a resistor that has a votage drop across it. You need a "star" ground that has all grounds together at one point then there is no ground wire for a voltage to develop across.
So i forgot to tell you that i have separate PCB board, one is power board and one is control board and only thin wires (flat cable) connecting them together so this is the main problem i must provide low resistance ground.
I have other question, why voltage on -op pin is not equal (aprox. 20% lower) then on +input pin (voltage follower orientation)??
Link to comment
So i have changed filter and improve ground and provlem with currenr spikes is now solved.
I was testing circuit with power supply instead of battery and i figured out that current decreasing with bat voltage decreasing which is not allowed, maybe because too small mosfet drain to source voltage, i must find 22e resistor and put it into circuit also but most probably this is not because of gate resistor missing??
Voltage on - pin is little bot lowe again that voltage of +pin of op i must solve this too.
Link to comment
If the input voltage does not change but the battery current reduces then the voltage across R4 also reduces and the LM324 opamp inverts and amplifies (minimum DC voltage gain is 25000 times) this voltage drop so that the current change is reduced to almost nothing.
Check to make certain that the LM324 opamp output is not saturated as high as it can go (1.5V less than the power supply voltage) and that the gate voltages of the Mosfets are much higher than their source voltages (your schematic does not show a part number for the Mosfets) because most Mosfets need up to 10V.
Link to comment
I am using mosfets IRFP460, regarding datasheet these transistor are suitable for project, i will check LM324 output voltage and then report values.
However problem is that battery voltage is reduce by high current so theoretically when 10A is flows out of battery, 5V is on R4, battery voltage could reach critical value arround only 9V (depends of battery healthy) and then source voltage of mosfet is only 4V, so mosfet can provide high current only on that condition, or not??
Link to comment
I measured 5.5v on op output when input voltage is 1v, then voltage on r4 resistor is 0.75v, current is 1.6a, power supply voltage was set on arround 11.8v.
So if increasing voltage of power supply (which represent battery) than current is increas to arround 1a and than stops increasing which is logically, so mosfet most probably not suitable for such a battery voltage.
Link to comment
What is the part number of your Mosfets? It should be on your schematic.
If the (+) input of the opamp is 0.8V and the current in the 0.5 ohm resistor is 1.6A then the (-) input of the opamp is also 0.8V. When you increase the battery voltage and the current tries to increase then it increases the voltage at the (-) input of the opamp that causes its output voltage to drop and turn down the current so that the current does not increase.
Use an input of 0.8V and a fairly low battery voltage. Measure and post here the (+) input voltage, the (-) input voltage and the opamp output voltage. Then increase the battery voltage and measure and post them again.
Link to comment
Thanks but i gave an example of measurements in previous posts, mosfets are IRFP460, so only problem is that voltage on - pin does not follows voltage on + pin, regarding mosfet transistor Vds should not be a problem for this case.
I wondering why voltage on - pin is lower than voltage on + pin and ouput voltage of OP is lower as i exepected - in upper case only 5.5V.
Link to comment
If the voltage on the (-) input of the opamp is lower than the voltage on the (+) input pin then the output will go positive which turns on the Mosfet more which should increase the voltage at the (-) input AND CANCEL THE INCREASE AT THE OUTPUT.
The datasheet for the Mosfet (not ebay fakes?) shows a graph for a "typical one" with Vgs= 5.5V then current= 22A but some are more sensitive and some are less sensitive.
Link to comment
I finally figured out where has problem been all the time, ground noise because battery connector.
PWM signal is on picture below and you can see oscilating on ground.
I solved this by putting 0.47uF capacitor between battery connector and signal is smooth and now voltage on -pin is the same as on +pin (which is suprising me, so voltage inequality reflected by input noise of OP????) but i must perform test also with higher current but for now this is part of solution.
Link to comment
  • 2 weeks later...
If i burdened battery or. increase discharge current reading of voltage becomes smaller.
I have 33kE and 11kE resistors serial from battery + pin to ground, so this is resistor divider, so if no current flows from battery there is normal reading, when current is higher reading is wrong or smaller as i said, for example battery voltage is 11.5V, adc reading is only 9.5V.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
