Jump to content
Electronics-Lab.com Community
What are discaps?
Guest nanop
They are adjustable Caps.
They have a very limited adjustment range.  When used in a tuned
circuit (radios)  They can sligtly alter the frequceny of a tank.
Sometimes used in production to adjust for cheap parts by tuning
systems up before they leave the factory.
Other times they can be use as part of a tuning mech such as a dial
on a radio (But that isn't actually the same thing; just a close relitive.)
-Mike
Link to comment
Share on other sites
About the discaps, I'm mostly confused about the shape of it, and why it has a turnable thing in the mid.
You're saying that it they are used for tunning, so their values change?
When I looked at the manual, it had fixed values for the discaps even though a screwdriver could easily turn the thing in the middle. The manual can be downloaded also from that site in message 1.
Here's a pic that might help:
Link to comment
I was unclear, My bad.
They are not designed for wide ranges (10uf -100uf) like variable resistors.
A closer analogy is a guitar string.  They are designed to make a particular note,
however it is up to the installer to tune it once it has been installed.
Caps that little (pF range) can be severely altered by the width of a trace or the
Length of a resistor.  If you NEED a very exact value, sometimes you need to install
A part with a little ‘wiggle’ room in the value.  The range is not very big. They are listed
By the TARGET value.  With some flex on either side.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
