1
nanokid
The 1uF/16V capacitors are only used at a few volts so only their value is important. Capacitors with a higher voltage rating will work the same but might be bigger. 1uF/25V or 1uF/35V might be small enough to fit on ther pcb.
You are using the pcb, aren't you? This circuit works at around 100MHz and won't work on a breadboard.
Are u kidding about the 1uf 16V electrolytic cap !  :)
Those can be bought just about anywhere. They can be bought online, and even at Radioshack, "that usually sucks"
Here's the site for Radioshack :
http://www.radioshack.com/product/index.jsp?productId=2062378&cp=2032058.2032230.2032267&pg=2&allCount=101&fbn=Type%2FElectrolytic+Capacitors&f=PAD%2FProduct+Type%2FElectrolytic+Capacitors&fbc=1&parentPage=family
Long URL...
BTW, Where r u from?
and what does the W mean after 1
yes Im using the pcb.  Im using batchpcb.com.  Ive used them before, much better pricing than advanced circuits.  and Ive looked on mouser and digikey for a 1uf 16v radial electrolytic capacitor and i haven't found them.  I even looked under tantalum but the only ones they have are non stocked and have outrageous mins.
Even EBAY sells Capacitors that will do the job.
LOT OF 1uF 16V AXIAL CAPS-LOOK!! Item number: 270020134485
http://cgi.ebay.com/LOT-OF-1uF-16V-AXIAL-CAPS-LOOK_W0QQitemZ270020134485QQihZ017QQcategoryZ4662QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
Mini Radial Electrolytic Capacitor ~ 1uF 50V (100) Item number: 170021781483
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170021781483&ru=http://search.ebay.com:80/170021781483_W0QQcatrefZC3QQfromZR2QQfviZ1
Non Polar Radial Electrolytic Capacitors 1uF 50V (25) Item number: 170012887414
http://cgi.ebay.com/Non-Polar-Radial-Electrolytic-Capacitors-1uF-50V-25_W0QQitemZ170012887414QQihZ007QQcategoryZ111603QQcmdZViewItem
