Herman the German Posted September 1, 2006 Report Share Posted September 1, 2006 Hello everybody,one of the forum members gave me this forums name to become a member. He thinks it will be helpfull for some of You having difficulties putting together an electronic device of a german kit concerning the language. I will be glad to help everybody out with translations and if necessary illustrations.Just let me introduce to You briefly. I am Hans, a retired GAF captain, having flown all kinds of aircraft for 23 years, last RF4-E Phantom. Since I handled my aircraft allright it always handled me right and I had no accident during my flying time.I have a problem concerning a timer schematic. That is what it is supposed to do:Count up and down, must be presettable for up and down count and stop counting after the preset time has elapsed thereby triggering a sound signal and a relay. I've got the schematic so far to count up using M74HC190 and the appropriate BDC to 7-segment decoder and LED driver but I have no idea about the "count down" part and how to switch back and forth. May be somebody has the circuit in his drawer and can help me.Thank You all for Your attentionKind regards Quote Link to comment Share on other sites More sharing options...
Guest 2old4digital Posted September 2, 2006 Report Share Posted September 2, 2006 You want to use a 74HC190, ok. If you can find The Book Digital Fundamentals By Floyd the 9th edition, you will find some help on or around page 445. This section covers up / down counters, also if you can find from the manufacture of the chip the spec. sheet that will help also. I'm glad the someone other than me at my age is doing Digital. Good luck and lots of success. Quote Link to comment Share on other sites More sharing options...
Herman the German Posted September 2, 2006 Author Report Share Posted September 2, 2006 ???I did NOT want to know that, wise guy! Quote Link to comment Share on other sites More sharing options...
ante Posted September 3, 2006 Report Share Posted September 3, 2006 Hi Herman,Welcome to our forum,We need to see the schematic to be able to help you. Can you please post it or supply a link to it? Quote Link to comment Share on other sites More sharing options...
MP Posted September 4, 2006 Report Share Posted September 4, 2006 Herman sent this message to the moderator:>>Thanks for Your offer to help. Do You prefer Eagle format or just a screen dump. Eagle version is 3.55<<I think it is meant for you ante.Best regards all,MP Quote Link to comment Share on other sites More sharing options...
ante Posted September 6, 2006 Report Share Posted September 6, 2006 Hi MP,Thanks,Herman: Not important what kind you use as long as you can post it here! Quote Link to comment Share on other sites More sharing options...
Herman the German Posted September 9, 2006 Author Report Share Posted September 9, 2006 Hello ante,I wonder why a *.sch (eagle) cannot be uploaded. The file has a size of 78 KB and I think Your mailbox can handle that size. Please send me an email to[email protected] and I will return the schematic.Thank Youkind regardsHtG Quote Link to comment Share on other sites More sharing options...
ante Posted September 9, 2006 Report Share Posted September 9, 2006 Hi Herman,I do not have Eagle installed in my computer; you can (while Eagle displays the circuit) make a screen dump (Prnt Scrn key) and post it here. 8)For the future (wouldn’t have helped in this case but); if you have a file with a suffix not allowed (like .sch) just ZIP or RAR it and it’s possible to post it. ;) Quote Link to comment Share on other sites More sharing options...
gogo2520 Posted September 9, 2006 Report Share Posted September 9, 2006 Hello Herman the German If you compress the file in a rar form or convet the file to gif, you can then upload it. Eagle has tools to convert any of your files to gif. Or bmp. Quote Link to comment Share on other sites More sharing options...
Shahriar Posted September 11, 2006 Report Share Posted September 11, 2006 You can Also build it with just a Microcontroller very simple and with lots of abilities.Of course building such circuits with TTL Ics is much more enjoyable.HTH - Shahriar Quote Link to comment Share on other sites More sharing options...
Herman the German Posted September 12, 2006 Author Report Share Posted September 12, 2006 You can Also build it with just a Microcontroller very simple and with lots of abilities.Of course building such circuits with TTL Ics is much more enjoyable.HTH - ShahriarA very good idea. maybe I can handle the hardware but not the software. The other way with wired logic is easy to understand and also easy to trace in case of malfunctions. I have made a lot of control units for industrial purposes, but never used a Microcontroller. Wired logic is just my thing! Even using a full size 19" rack with up to 17 PCBs doesn't bother me at all. Boole's algebra is logic. A small piece of (SMD mounted plastic or ceramic) is not logic and will become as intelligent as the programmer is.sincerelyHtG Quote Link to comment Share on other sites More sharing options...
Shahriar Posted September 12, 2006 Report Share Posted September 12, 2006 ِDear Herman For Counting down the UP/Down pin should taken low.if you want when counting is finished, the counter resets, you should connect the Max/Min output to Load Input via a NOT gate or a NPN transistor While all Outputs are pulled down via Appropriate Resistors (If IC doesn't have Internal Pull down Resistor, Check it). you can also use this Transistor to trigger your Buzzer or LED.If you want your Buzzer make sound for some seconds, you can build a Monostable by 555 and connect the buzzer to 555 output. I don't know if this is your Problem. ???HTH - Sahriar Quote Link to comment Share on other sites More sharing options...
Shahriar Posted September 12, 2006 Report Share Posted September 12, 2006 Here another Useful link for IC 4510 - I think this is all you need.http://www.doctronics.co.uk/4510.htmShahriar Quote Link to comment Share on other sites More sharing options...
flexofab Posted September 14, 2006 Report Share Posted September 14, 2006 Dear Herman,Please Visit this site for Quote Link to comment Share on other sites More sharing options...
Herman the German Posted October 6, 2006 Author Report Share Posted October 6, 2006 Thank you for your help. I checked it and just found a timer. This is not what is on my mind. The timer should have the following properties: Count up and down 999.99 seconds and use optoelectronics to start (car races for instance), switch off the microwave oven after the exact preset time and work as a photimer as well to expose PCBs.I just have difficulties with the pins clock in, clock out, borrow and carry since they are not described thoroughly enough in the data sheet.RegardsHtG Quote Link to comment Share on other sites More sharing options...
