newonetoo Posted September 6, 2006 Report Posted September 6, 2006 I hope this is a better question then the last one I gave. Can anyone assist in making a 7.5 amp 12v circuit breaker. Doing work on the bike keeps blowing those mini fuses. Which are not cheap. Quote
Theatronics Posted September 8, 2006 Report Posted September 8, 2006 my best guess? Try about a 32-34ga wire.Id suggest you build a rig with 2 terminals that you can wrap the wire around and then cover with a shield. Wire going vapor can be dangerous.for a few bucks you can buy a circuit breaker.You can also use a 'shunt' resistor, a RS flipflop and a mosfet.Run the circuits ground into the drain of the n-channel mosfet.Connect the drain to the ground.Set up the shunt resistor so that when the target current is flowing though it you can read about 3-4 volts. ( 4v / 7.5 amps = 0.53 ohms )Take the output of that measurement and feed it into the SET input of the flipflop.When the current gets close to 7.5 amps, the voltages at the flop/flop input will be high enough to cause the f/f to toggle states. As a result the /Q (not Q) output of the f/f will go low. When this happens the N-Channel Mosfet will shut off and the circuit will shut off.-Mike Quote
ante Posted September 9, 2006 Report Posted September 9, 2006 You could use one of these, 6 or 8 A will do:http://www.elfa.se/elfa-bin/setpage.pl?http://www.elfa.se/elfa-bin/dyndok.pl?lang=en&dok=2013541.htm Quote
