nickagian Posted September 16, 2006 Report Share Posted September 16, 2006 Hi all!Does anyone have a datasheet from a ceramic resonator (it doesn`t matter which)?Basically what I want to know is which pin is what!Can anybody help me with that? Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 16, 2006 Report Share Posted September 16, 2006 It makes a big difference. There are ceramic resonators for AM radios, FM radios, shortwave radios and many other applications. There are many manufacturers, shapes and sizes. Digikey lists 563 different ones for sale. Which one? Quote Link to comment Share on other sites More sharing options...
nickagian Posted September 16, 2006 Author Report Share Posted September 16, 2006 :o I didn`t know it and unfortunately I don`t know exactly what resonator I have.However I can tell that it has 3 pins and I have bought it to use in a project with a PIC microcontroller, if that helps you.. Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 16, 2006 Report Share Posted September 16, 2006 You bought something and you don't know anything about it. Really?It has an input, an output and a ground. The input and output pins can be swapped, and the center pin is probably the ground pin. Quote Link to comment Share on other sites More sharing options...
nickagian Posted September 16, 2006 Author Report Share Posted September 16, 2006 I have asked for a ceramic resonator at about 10MHz for my microcontoller project and I was given this one...the only thing that is written on it is "L10.7A",which I guess shows the frequency, 10.7MHz...that is all I know about it! Oh and it has a red dot above one of the side pins..It has an input, an output and a ground. The input and output pins can be swapped, and the center pin is probably the ground pin.But thanks anyway, because that is what I was looking for... I didn`t know which pin is for the ground... Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 16, 2006 Report Share Posted September 16, 2006 You have a wideband tuned circuit for shaping the IF of an FM radio. A microcontroller uses a narrowband resonator that is like a quartz crystal. Try the one you have, it might work. Quote Link to comment Share on other sites More sharing options...
mvs sarma Posted October 12, 2006 Report Share Posted October 12, 2006 here goes a pdf of ceramic resonators sarmaceralock.pdf Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted October 23, 2006 Report Share Posted October 23, 2006 Nice Datasheet. Here is a non electric Ceramic Resonator LOL Quote Link to comment Share on other sites More sharing options...
mvs sarma Posted October 23, 2006 Report Share Posted October 23, 2006 hi HotwaterwizardSO NICE A Resonator like to see it in 4th dimension--(i mean some one performing on itsarma Quote Link to comment Share on other sites More sharing options...
MP Posted October 26, 2006 Report Share Posted October 26, 2006 You have a wideband tuned circuit for shaping the IF of an FM radio. A microcontroller uses a narrowband resonator that is like a quartz crystal. Try the one you have, it might work.Actually, that is not so. What he has is also used for microcontrollers. They are perfect for this application and much cheaper than a crystal. Just ground the middle pin and either of the outside pins can be connected to either of the clock pins on the micro. I have a drawer full of these for this application. I never use a crystal for a micro project, except for specific conditions where I need it. Resonators are commonly used instead of crystals. They take up less space on the pc board since you do not need the capacitors. It also sometimes eliminates routing problems on a pc board. ...of course, mine are much smaller than Hotwaterwizard's resonators ;DMP Quote Link to comment Share on other sites More sharing options...
audioguru Posted October 26, 2006 Report Share Posted October 26, 2006 Actually, that is not so. What he has is also used for microcontrollers.MPHis is 10.7MHz which is a wideband ceramic filter for the IF of an FM radio. Microcontrollers also use a 3-pin ceramic resonator but they are narrow-band and are 0.5% accurate.Digikey has a 4.000MHz 3-pin ceramic resonator with the capacitors built in for only $.34US each. Ceramic filters for FM radios cost much more. Quote Link to comment Share on other sites More sharing options...
MP Posted October 26, 2006 Report Share Posted October 26, 2006 Sure, 10.7 MHZ is a size used for IF, but micros also use various size Crystals for specific purposes. A 10.7 MHZ Resonator (or Crystal) will give you almost 3% less error in RS232 data transmission at 57600 baud than a 10 Mhz Resonator (or Crystal). I don't know what OP purchased since I am not clairvoyant, but I would be surprised if it did not work for this purpose. Even a digital gate based clock will work for a micro.MP Quote Link to comment Share on other sites More sharing options...
ElectronicsGeek Posted November 6, 2006 Report Share Posted November 6, 2006 10.7MHz resonator will work with microcontroller, even if it is defined as working up to 10MHz maximum.However, the problem comes when if the program is written with the frequency of 10MHz, and now working with 10.7MHz things must happen in the wrong way.Be careful with the 3-pin ceramic resonator (pin order always is: input-ground-output), as in some devices, the manufacturer already adds the internal caps across input and output to ground, so the enduser must not use the external caps. The only way you know that is identifying part from its marking on package and look up in the manufacturer's datasheet.ElectronicsGeek Quote Link to comment Share on other sites More sharing options...
