Chris 50 Posted September 17, 2006 Report Share Posted September 17, 2006 Hi AllJust a thought i would post these oscilloscope plans from old uk magazines could make good projects. good luck, drop me a line if you have a go at building one and if all works ok.RegardsChris 50 [attachment deleted by admin] Quote Link to comment Share on other sites More sharing options...
gogo2520 Posted September 19, 2006 Report Share Posted September 19, 2006 Hello Thanks for the links Chris 50 I never used a oscilloscope, so I do not know what would be a good one to start out with. I found this one, http://www.electronickits.com/gold/st16b.htm Not sure if its a good choice. I am just a hobbist and don't really need one but still it be nice to have one. Thanks for any input. have fun gogo Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 19, 2006 Report Share Posted September 19, 2006 That 'scope kit is the cheapest that I have seen for more than 40 years.It has only a single channel. Most 'scopes have two so you can compare signals, pulses and their timing.It has a pretty small screen but is OK for a hobbiest.It has a low bandwidth but is OK for a hobbiest.It is about the same as the kit 'scope that I have used for 40 years. It is a lot better than nothing. ;D Quote Link to comment Share on other sites More sharing options...
gogo2520 Posted September 20, 2006 Report Share Posted September 20, 2006 Thank You audioguru for what I am planing on useing it for it should do. I just want to learn more about small amps and stuff. gogo Quote Link to comment Share on other sites More sharing options...
Chris 50 Posted September 20, 2006 Author Report Share Posted September 20, 2006 Hi, gogoThanks for reply. I'am also new to the hobby of electronics, i have a cheap scope about 5Mhz in spec, its ok for me being a newbie and all that, i shall be trying to build my test gear, i think this is a good way to learn, my soldering is ok i use a antex iron small wattage with a 0.5mm tip, works fine for me, i have under construction a fcl_x meter which will test caps-freq counter-xtals i have etched the pcb all went well, and iam busy mounting all components to the board no problems so far_ web address is, http://www.hamradioindia.org/circuits/fcl.phptake a look they have given the meter good remarksAS for software PCB WIZARD was my first program - have moved to EAGLE and finding my way round this along with Eagle 3D from this site wow !!.Keep in touchRegards, chris 50. Quote Link to comment Share on other sites More sharing options...
gogo2520 Posted September 21, 2006 Report Share Posted September 21, 2006 Hello Chris 50 Nice link thanks. I too use eagle and pcb wiz, I like both sometimes when I have something simple I use pcb wiz. For the hard ones I use egale, it has more componeits and has more options. I down loaded that project and will attach the files to this post. Like I said thanks have fun gogofcl_meter.zipfcl_pcb.zip Quote Link to comment Share on other sites More sharing options...
