Jump to content
Electronics-Lab.com Community
Shahriar
50Hz when you touch Oscilloscope probe
Your body is an antenna for picking up 50Hz mains radiation. Same thing happens if you touch an amplifier's input, it produces a loud 50Hz.
That is why the scope's cable and audio cables are shielded.
If your heart fibrillates at 50Hz instead of 50 bpm, then you are having a heart attack.
Share this post
Link to post
Share on other sites
Dear Audioguru
1- I Connect the Probe to an Antenna and a 50Hz signal appeared with pick voltage about 2V.
2- when I touched the antenna while it was connected to Probe a 2.2V 50Hz signal appeared.
3- when I touched the probe a 50Hz, 6V signal appeared
4- when I touched the probe a 50Hz, 5.7V signal appeared while I was standing over some papers.
if it was all radiation so what is the roll of those papers, maybe If you examin it, find more useful things.
ThanX
Shahriar
Share this post
Link to post
I understand it's your body's capacitance with ambient that couples you to the mains. A few picofarads. That's enough to deliver a volt or so to a high impedance at 50Hz. It is electromagnetic in nature, of course, but I suggest that "picking up mains radiation" is misleading.
Share this post
Link to post
Hi Zeppelin,
An elsctrostatic field works with AC or DC.
There is a very small amount of capacitance from nearby mains wiring and your body.
There is a small amount of capacitance to ground at the 'scope probe.
The capacitances are joined in series at your body and make a capacitive voltage divider.
Share this post
Link to post
hi audioguru ,
thats a strange thing u told.in india we have mains frequency as 50 Hz .Does our body pick only 50 Hz ?
If i am in a country with 30 Hz mains frequency and there i touch a CRO with a fan blowing over me ,what will i get on screen?
30 Hz or nothing?
In other words, is our body tuned to 50 Hz or any mains frequncy noise around us?
Share this post
Link to post
Hi Prateek,
If your home or lab has electrical outlets on each wall and electrical lights on the ceiling then you are surrounded by high voltage AC at the mains frequency. Your body or a piece of unshielded wire will pick it up. It doesn't matter if there is a fan and the frequency doesn't matter.
Share this post
Link to post
I believe the answer is "leakage current" in conjuntion with a capacitive divider (as mentioned above). If your hands are moist, touch the tip of the scope probe with one hand and the scope ground wire between two fingers with the other hand. Squeeze the ground wire harder between your fingers, and watch the waveform... it will change in aplitude and will always be of the same freqency as the local line voltage. Guess what happens if you do this with battery operated scope? When I say "moist hands", I don't mean with water, I mean with perspiration, which, because of salt content, is a better conductor than plain water.
Share this post
Link to post
no audioguru,
i think u did not get my question .my question was does our body pick up only 50 Hz or any frequency signal by which it is surrounded say even a 30 Hz or 100Hz .
in other words ,,
is our body an antenna tuned at 50Hz or does it get automatically tuned to any frequency around it?
Share this post
Link to post
Dear Audioguru
A TV tuner is designed to receive a voltage around 400uV Upto 600uV From antenna. then how our body can produce a 6V signal. I think there are some other reasons in addition to electromagnetic in creating such big signal.
shahriar
Share this post
Link to post
Your body isn't tuned. It has a large surface area, is conductive (less resistance than the input of a 'scope), is insulated from ground and therefore picks up any signals that are there.
A TV station is far away so a TV tuner needs good sensitivity by amplifying the signal. Hundreds of volts of mains is very close and is surrounding you, so if you touch a 'scope's input then a few volts are shown. Connect an unshielded piece of wire to the input of a 'scope or a microphone amplifier. You will have the same mains hum.
Share this post
Link to post
Yes, as I said, capacitative coupling. I'm pretty sure there is almost no electromagnetic phenomenon involved in 50Hz mains pickup.
The body's capacitance to ambient electric fields is a few picofarards. When you touch the scope probe, you become a 10pF capacitor in a series circuit - a 50Hz 110V/230 AC signal generator, in series with a 10pF capacitor, in series with a 1MOhm load (the probe) to ground.
That's a cut off frequency of several kilohertz, meaning the 50Hz 'signal' is hugely attenuated.
This is what I believe to be the dominant effect here.
Share this post
Link to post
Mains radiation is all around you at 50Hz. The long wires and tracks on a breadboard pickup interference.
Maybe the power supply is grounded or has some capacitance to ground then the circuit's wires are an antenna. With the battery then there isn't a ground so the antenna effect from the wires isn't as strong.
Maybe the clock pin on the counter IC doesn't have a low impedance path to ground.
Maybe the power supply has a lot of 50Hz ripple.
Share this post
Link to post
this problem is prevelent even with 74 series . a cct rigged up on a prototype had misarably failed due to noice pick-up. perhaps with proper precautions towards poer decoupling at each IC and by keeping poer extention boards, etc away from the project prototype, and by sticking the specific metal sheet supplied with the bread board, beneath and keeping at earth potential, we may suceed in preventing the power pickup problems.  all of us are aware of antisattic wrist straps with earthing cwire etc . these are to be specifically used when working CMOS digital ICs and in locations of low relative humidity.              (  B series, now a days are ruggedized by protection diodes across every pin  to prevent failure, induction is stil a problem) . whether one measures 50/60Hz or a hormonic depends perhaps on the amount of induction and amount of noice generated by devices adopting triac conrollers- even after all the reglations reg power purity.
hope with adequate precautions one could still prototype and test on bredboards.
anxious to track the success of test rig ups.
sarma
Share this post
Link to post
Inside Your Scope there are two capacitors vith value about 10nF connected between Mains lines and case of Scope for filtering purposes. they Create some AC voltage on Scope Common. Scope Shows voltage between common and probe. When You tuch probe You ground it by Your Body capacitance so voltage difference is created. To avoid this simply ground the scope common.Scope must have spetial coonnector for Grounding
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
