Jump to content
Electronics-Lab.com Community
non stepper motor controlling bridge problem
reko
Hey everyone well Audio Guru u helped alot in the sensors topic i would like to ask again for help on a certain subject i found all of u guys making a hell of a discusion about well
I was planning on controlling a dc motor with brushes and commutator to work with atmel at89c2051 mcu (Using pulse width modulation) well i got everything from the tutorial u linked here about the pwg through a bridge to control motor and btw the code there is simple i am a computer science student so i know about it the problem here is that i planned to use the l293d which is equipped with spike-protecting diodes and rated 600 mA per channel but the only bridge i managed to get is a l293B which isn't equipped with the diode and also rated 1A per channel that could be a problem so my question is (Is it possible to use that bridge with a dc non-stepper motor or what?)
P.S:Audio guru u really helped last time i hope u do this time :)
Link to comment
Share on other sites
Its datasheet shows where to connect external diodes and how it is used with DC motors having brushes and a commutator.
If your motor draws more than 1A when starting, working hard or is stalled, then the IC will make lots of smoke.
Link to comment
Search Results
L293B and L293E
http://www.st.com/stonline/books/pdf/docs/1328.pdf
L293D
ST Datasheet
http://www.st.com/stonline/books/pdf/docs/1330.pdf
TI Datasheet
http://focus.ti.com/lit/ds/symlink/l293d.pdf
App Notes
http://msgroups.tech.northwestern.edu/dc/dc99/docs/l293eapp1.pdf
http://www.st.com/stonline/products/literature/an/1675.pdf
Other Info
http://www.cse.cuhk.edu.hk/~khwong/ceg3430/mrobot7.pdf
http://www.dprg.org/projects/1998-04a/
http://www.seattlerobotics.org/encoder/may98/steppers.html
http://www.cs.uiowa.edu/~jones/step/circuits.html
http://www.stanford.edu/~pjc30943/school/ME218%20labs/KrisPaulSal%20-%20Lab%208%20Report.doc
http://www.me.umn.edu/courses/me2011/robot/technotes/L293/L293.html
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
