nickagian Posted September 25, 2006 Report Share Posted September 25, 2006 Hi all!I am confused a little bit with something related with the IC 74LS07.This IC has buffers, isn`t that correct? So let`s choose the first gate and apply +5V at the input (1A). I expect to get +5V at the output of the gate (1Y), right? So why is that not working with my chips? ??? (I have already checked two of them).I cannot understand what is my mistake... :( Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 25, 2006 Report Share Posted September 25, 2006 The datasheet and description of it says, "open collector outputs". Its outputs are transistors to ground. A load or a resistor between the output and a positive voltage is supposed to pull the output voltage high. Quote Link to comment Share on other sites More sharing options...
nickagian Posted September 25, 2006 Author Report Share Posted September 25, 2006 I guess you are right... I have a problem with one circuit containing the `07 and thought it was burned...so I checked it seperately and found this behaviour strange. But you are right with that open collector. Thank you! Quote Link to comment Share on other sites More sharing options...
