techmax Posted October 9, 2006 Report Share Posted October 9, 2006 i was thinking of making a fm transmitter and ruled out this one (for ham ofcourse)http://www.electronics-lab.com/projects/rf/001/index.html1.will it give the stated power output 4W?2. what will be its minimum range with a 75cm telescopic antenna?thanks, this site really rocks Quote Link to comment Share on other sites More sharing options...
techmax Posted October 10, 2006 Author Report Share Posted October 10, 2006 c'mon guyz one whole day and still no replies :( this my first post guyz,don't do this Quote Link to comment Share on other sites More sharing options...
audioguru Posted October 10, 2006 Report Share Posted October 10, 2006 It isn't a good circuit since its RF frequency drifts.It will sound lousy since it doesn't have pre-emphasis (treble boost) like radio stations.It isn't stereo.Its high output power is illegal so maybe nobody made it.The Micromitter FM transmitter project and kit is much better:http://electronics-diy.com/schematics/BH1417_fm_transmitter.htmhttp://electronics-diy.com/BH1417_PLL_Stereo_FM_Transmitter.php Quote Link to comment Share on other sites More sharing options...
techmax Posted October 11, 2006 Author Report Share Posted October 11, 2006 thanks audioguru for ur reply there is no problems of legal issues here because i hold a license for fm transmission upto 50 watts.the links u provided were good but the power output was really less and so the rangeplz give ur comments on this one-http://www.electronics-lab.com/projects/rf/019/index.html1.what is ayxnia?2.807 is quite inefficient(20-25w heat dissipation) suggest a better one. Quote Link to comment Share on other sites More sharing options...
audioguru Posted October 11, 2006 Report Share Posted October 11, 2006 I have never been a ham and I haven't used vacuum tubes since about 42 years ago.There are websites for "radio pirates" that use more modern designs for VHF power amplifiers. They also have much better and more modern FM "exciters". Quote Link to comment Share on other sites More sharing options...
point2006 Posted October 31, 2006 Report Share Posted October 31, 2006 Brother i want to make fm transmiter but at this time i m collecting very intial material about.i have a very short and simple circuit but the circuits on net are different from it.The basic problem i m facing is of its theory.i m loking forward to make some other projects as well u can help me.if u need that circuit i can post it to u. Quote Link to comment Share on other sites More sharing options...
audioguru Posted October 31, 2006 Report Share Posted October 31, 2006 Hi Point,Attach the schematic and parts list of the transmitter you are talking about for us to see if it is good or bad. Quote Link to comment Share on other sites More sharing options...
frobnic Posted March 29, 2007 Report Share Posted March 29, 2007 Does this circuit really work or not ? I thought I could build it but is it worth it i would be happy with two or three watts if it just works. I have experience about building electronic circuits but i cant say if this works or not can you?frobnicFinland,Helsinki Quote Link to comment Share on other sites More sharing options...
frobnic Posted March 29, 2007 Report Share Posted March 29, 2007 I found some other possible -and what they said- better transistors at other forum and i was wondering you-audioguru- could tell me if they work better than the original ones?The transistors are for T!:2n2222,2n2222a,2n2219,2n2219a,bsx20 or 2n3904T2:2n4427,2n3866,2n3924,2n3553 Quote Link to comment Share on other sites More sharing options...
audioguru Posted March 29, 2007 Report Share Posted March 29, 2007 Hi Frobnic,Welcome to our forum. ;DWe have two "4W FM Transmitter" projects. Which one?I think it is the simple one with only 2 transistors. I don't think its output will be 4W unless you use a 16V supply and the output transistor gets extremely hot. The oscillator transistor will also get hot.It is a very simple old circuit:1) It doesn't have the crystal of modern FM transmitters so its frequency will drift.2) It doesn't have pre-emphasis (treble boost like FM radio stations have) so it will be heard on an FM radio without treble audio frequencies, like your stereo with its treble control turned all the way down.3) It is mono, not stereo.Transistors are all different, even if they have the same part number. Try a few.Is it this project? Quote Link to comment Share on other sites More sharing options...
