Shahriar Posted October 9, 2006 Report Share Posted October 9, 2006 HiI can remind some times ago some one has written that it is better to replace 85'C Caps with 105C caps in old devices. (I think it was audioguru)Today, I was reading an article about SMPS troubleshooting. Look what a repair man has said:"(From: Jeroen H. Stessen ([email protected])Electrolytic capacitors like to be kept cool! If there's anything that these capacitors can't stand, it's heat. It causesthem to dry out.Electrolytic capacitors exist in (at least) two different temperature ratings: 85 C and 105 C. The latter areobviously more temperature resistant. Unfortunately they also tend to have a higher ESR than their 85 Ccounterparts. So in an application where the heat is due to I^2 * ESR dissipation, the 105 C type may actually be a*worse* choice! If the heat is due to a nearby hot heatsink then 105 C is indeed a better choice."Is it really true? ::)ThanXShahriar Quote Link to comment Share on other sites More sharing options...
Shahriar Posted October 9, 2006 Author Report Share Posted October 9, 2006 Look what another guy has said about this topic:ESR is usually something to be minimized in a capacitor. However, where the original design depended (probablyby accident) on a certain ESR, this may not always be the case:(From: Lee Dunbar ([email protected]).)Substitutions of low ESR caps into circuits which had lousy caps is not always the good idea that it appears tobe.... Caution is advised, as low ESR caps will not limit surge currents.The circuits' series impedance drops (compare substituted capacitors ESR when new with the original capacitor'sESR was when it was a new capacitor), which, in turn, lets the surge magnitude rise, the higher currents destroycan semiconductors and other components.I guess what the industry needs is a good capacitor cross reference guide for aluminum electrolytics! Quote Link to comment Share on other sites More sharing options...
mvs sarma Posted October 10, 2006 Report Share Posted October 10, 2006 ESR stands for equivalent series resistance of an eleco. no componenet being ideal, the elec caps used for filtering the output shold be of low ESR and such caps are being supplied as esr caps. you may search for addl data on the subjectwww.e-sonic.com/whatsnew/emag2004_3/emag_Passive_nic.pdf sarma Quote Link to comment Share on other sites More sharing options...
indulis Posted October 11, 2006 Report Share Posted October 11, 2006 It really depends on the application. ... the heat is due to I^2 * ESR dissipation...This is true, but you have to use the RMS value of the ripple current, something that is not always easy to calculate or measure. Sometimes you want ESR to be high, sometimes you want it to be low. For example... in a SMPS, the input filter likes a higher ESR to... 1) kill the "Q" and 2) change the filters "output impedance" relative to the input impedance of the converter (DC-DC conveters can look like a negative input impedance and there can be interaction which can cause oscillations). Output cap's like low ESR to reduce ripple, but the transfer function has a "zero" caused by the output capacitance and its ESR which can be a pain when trying to stabilize the feed back loop. Quote Link to comment Share on other sites More sharing options...
