Jump to content
Electronics-Lab.com Community
Body Resistance help
Korslain
I'm a beginner at electronics. I wanted to see what my body resistance would be, by first putting the 2 test leads of the ohmmeter on one hand. If I put one lead on my right hand, and one on my left, it should have a higher resistance reading than having the 2 test leads on just one hand, because the current would pass from one hand to the other.
When I did this, both tests had the about the same resistance readings, y would it be the same?
Link to comment
Share on other sites
Hi Korslain,
Welcome to Electronics-Lab!
There are quite a few factors involved in this. Here is a portion of an ohm's law tutorial that goes a little into depth about body resistance:
http://www.allaboutcircuits.com/vol_1/chpt_3/4.html
Hope this helps. Also note that there are books written about this very subject. Much research has been done in this area.
MP
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
