Jump to content
Electronics-Lab.com Community
Frequency Division
How can i reduce a 4mhz frequency to a 10hz freq?
In the power field we use a drive circuit. This means we rectify the signal, then using an inverter reconstruct the wave at the frequency that is desired.
In a low power application I am not sure what the most efficient method would be.
Link to comment
Share on other sites
With a 5V supply, an ordinary Cmos counter is guaranteed to work with a clock frequency as high as only 1.5MHz. A 74HC counter works at much higher frequencies so use a 74HC90 to divide the 4MHz to 400kHz.
Feed the 400kHz to two CD4518 dual divide-by-10 counters in series for an output of 40Hz. Then use a CD4013 dual flip-flop for exactly 10Hz.
The total is 4 ICs.
Link to comment
Joe,
If you have some experience with microcontrollers, you can do this pretty easily. Count the pulses coming in and send a pulse out another pin after every so many counts. As long as you use a micro with a faster clock than 4 Mhz, it will work fine. This is on the same lines as what hotwaterwizard, ughadoo and audioguru suggested but with less parts count.
MP
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
