ashray Posted December 26, 2006 Report Share Posted December 26, 2006 hi.. i'm using DAC 0808 for the first time.. and i couldnt figure out the pins Cc and Vlc in the following schematic.... pls help me out.. sorry if i've posted this in wrong thread.. couldnt figure out the right one.. Quote Link to comment Share on other sites More sharing options...
aniruddha Posted December 27, 2006 Report Share Posted December 27, 2006 hi ashray, i m a newbie too and actually this is my first post so excuse me if theres any mistake ;DI read a book on D/A--A/D convertors ... but in the book 0808/0809 monolithic CMOS devices were mentioned as Analog to Digital convertors so is that what u meant? Quote Link to comment Share on other sites More sharing options...
ashray Posted December 27, 2006 Author Report Share Posted December 27, 2006 ya. this is a digital 2 analog.. i wanted to know what the two pins that i've highlighted mean.. Quote Link to comment Share on other sites More sharing options...
Ashtead Posted December 29, 2006 Report Share Posted December 29, 2006 The schematic shows a DAC-08, (Analog Devices) which National Semiconductor calls DAC-0800, and this one is similar to, but not quite identical with the DAC-0808, or MC1408/MC1508 that other manufacturerers may call it. The DAC-08 is somewhat more flexible, in that it may be used in some different configurations with non-grounded outputs, and with different, though now mostly obsolete, digital logic levels. It is somewhat unfortunate that the part numbers are so similar... The differences have to do with the electrical connections of pins 1 and 2, pin 1 being one of the "mystery pins". Pin 1 is "VLC" on the DAC-08 and simply not connected at all on the DAC-0808. The purpose of this pin, on the DAC-08 is to be able to set different logic thresholds for the digitat inputs, that is, the voltage, at which the circuit determines whether the inputs mean "0" or "1". The data-sheet that I have here indicates that the threshold voltage is 1,4V plus whatever is applied to the VLC pin. For low-voltage logic (3.3V-5V CMOS or 5V TTL) the 1.4V is just about right, so the VLC pin can be tied to 0V for this use. The datasheets shows examples of using 15V high-voltage logic, and then the threshold voltage should be raised to 7.6 V, by feeding 6.2 V generated with a zener diode into VLC. The DAC-0808 has a fixed theshold, at around 1.4 V, which makes it suitable for being driven by 5V TTL or CMOS, just like the DAC-08 when this pin is at 0V (or ground). As this pin is not connected on the DAC-0808, it doesn't really matter.Pin 2 is "/IOUT" on the DAC-08 and identified as GND on the DAC-0808. What this means is that the connection from this pin to the non-inverting input on the following op-amp should be at a hard 0V level for the DAC-0808, but does not have to be on the DAC-08. Your circuit diagram shows this connection at a different level; thus in this circuit, the device must be the DAC-08, and a DAC-0808 may not work very well. (it probably will still put out something that looks kinda right, but as it's GND pin isn't really grounded, all bets are off when it comes to accuracy or linearity or such things that are important with D-to-As). The other pin that needed explanation is pin 16, "COMP", which is there for the same reason on either the DAC-08 or the DAC-0800. This capacitor provides frequency compensation in the reference amplifier inside the converter, where the reference voltages and current between pins 14 and 15 is distributed to the 8 current sinks, one for each bit, that may be turned on or off, to make the resulting combination of current be drawn into IOUT output. It is likely that the transistors associated with this amplifier stage will be self-oscillating if this capacitor isn't present. Its value depends on the resistances connected to pin 14, the data-sheet indicates minimum values of 15pF for 1 kOhm or 75 pF for 5 kOhm. This may be of interest if the DAC is to be used as a volume control or multiplier for a fast-moving signal.Many of the examples show this capacitor with a value of 10 nF or 100 nF, which is useful when Vref is supposed to be a stable DC voltage. Here are links to some of the manufacturers' datasheets:http://www.national.com/pf/DA/DAC0808.htmlhttp://www.datasheetcatalog.com/datasheets_pdf/M/C/1/4/MC1408-8.shtmlhttp://www.analog.com/en/prod/0,2877,DAC08,00.htmlhttp://www.national.com/pf/DA/DAC0800.htmlHope this clarifies things. Ashtead Quote Link to comment Share on other sites More sharing options...
ashray Posted December 29, 2006 Author Report Share Posted December 29, 2006 hi... thanks a lot ... it cleared a lot of things....i found this application note in the dac 0808 datasheet... but i guess this schematic is for unipolar operation...can i convert it to a bipolar operation circuit by giving a reference voltage to the non-inverting terminal of the op-amp?? Quote Link to comment Share on other sites More sharing options...
