Jump to content
Electronics-Lab.com Community
Total voltage drop in series circuit
bitem2k
Im currently reading a book on electronics, that says that the sum of the Voltage drops across all components tied in series should equal the voltage of the battery.
However i tested cicuit on a breadboard with a led and a resistor, and measured the drops accross each and added them together. They did not add up to the supply voltage.
Anyone have any ideas?
Thanks very much. :)
Link to comment
Share on other sites
Thanks for the reply.
worked out what the problem was.
This is very strange, but i was using a Nokia Charger which provides 8.78V with nothing connected., but for some reason when you measure the drops across everything connected (resistors) in series, it looses a volt or two!
Any idea why?
thanks
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
