ringing detection circuit
Hi all..
I have a problem here.
i tried to build a ringing detection circuit.
But when i connect the ring and tip of the telephone cable to this circuit,i found out that it automatically being off hook.
As a result,it cant be used to detect the ringing signal and it get engaged when i call to the telephone.
Is there anyone who can explain to me why it get off hook even there are no ringing signal?
Thanks in advance
The telephone ringing signal in North America is 90VAC. Your zener diodes are only 3.3V and the 330 ohm resistor creates a huge current with a peak of 370mA. I am amazed that your opto-isolator didn't burn out.
Look at all the ringing detector circuits in Google that use 15V zener diodes and a 10k resistor like this one from a modem:
Hi guru
Nearly every LED has a max reverse voltage rating of only 5V.
It is a good point for me to put in my memory. But there remains a question: whether such a diode (4148) can bears this 127v ?
Hi  mvs sarma
we can also use a DIAC (conducts  at  32 volts in each diection)
This point is excellent and wonderful, thank you
