Jump to content
Electronics-Lab.com Community
Posted
I need datasheet and/or manual for over current relay manufacturer by mitsubishi electric corp.
Type   CO-18-R JEC-174A
Rating 2A 50Hz
Range 0.5-2.5A Style PG060
ICS 0.1/1.0 A
RATED VA 30VA
SER 81577 DATA 1982
Best Regards.
Posted
Hi hotwaterwizard,
I have the url for the over current relay, but not for the datasheet/manual of it,
i need help to find where i can buy this device from.
Best Regards,
http://www.mitsubishielectric.co.jp/haisei/01sei/data/data02sei_kikaku/relay/tekiyou/index.htm
* Standard of protected machine
JIS (the Japan Industrial Standard)
JIS C 4601 High pressure receiving electricity site connect relay device
JIS C 4602 Overcurrent relay for high pressure receiving electricity
JIS C 4609 High pressure receiving electricity site connect direction relay device
JEC (Institute of Electrical electric standard committee standard)
JEC-2500 Protected machine for electric power (old JEC-174)
JEC-2510 Overcurrent relay (old JEC-174A)
JEC-2511 Voltage relay (old JEC-174B)
JEC-174C High resistant ground type site connect directional relay
JEC-174D Auxiliary relay for electric power
JEC-174E Slow-operating relay for electric power
JEC-174F Comparative operation relay
JEM (the Japanese electrical machinery and appliances manufacturer's association standard)
JEM 1336 High-tension distribution line site connect directional relay
Posted
search results
Rating 2A 50Hz
ICS 0.1/1.0 A
RATED VA 30VA
SER 81577 DATA 1982
JEC-2510 Overload Relay
www.chinait.net/xinghao.asp?id=25145
http://www.ca800.com/product/html/2007-1-1/p19401.html
http://fonlee.fonlee.com.tw/Proc/O/omron/pdf/R/K2CG.pdf
http://fonlee.fonlee.com.tw/Proc/O/omron/pdf/R/K2ZC.pdf
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
