Jump to content
Electronics-Lab.com Community
UPS Problem
johnc12
Helow guys,
Well as a new guy here in office I don't have any knowledge in troubleshooting.... After the busted monitor, now my problem here is the APC ES 500 model BE500-PH. I can't find any schematic that could help me and APC refuse to give me one... My problem is this, my UPS wont start and I found out that one of the MOSFET (IRF740) is burned. I replaced it with a new one but the unit still wont power on. Hope you guys could help me troubleshoot. I have 3 more UPS, the same unit and similar problem, unit wont turn on.
I will really appreciate any help that will come. If you have question, don't hesitate to ask.  :)
Link to comment
Share on other sites
I see, the irf740 is in parallel with 3 irf740 also. I can see that it is found near the ceramic caps and the source. There are also some burned resistors and transistors near the mosfet but it is too small to determine, and I think they are defective too.
I would be glad to see you're APC 500 schematic and see if it matches on my unit here.
Thanks ante.
johnc
Link to comment
hehe. Ante, I tried to check the UPS using you're diagram but it shows only little similarity on the pcb. The mosfets, resistors and caps are hard to find and not the same as irf740. My supervisor and I decided to indicate the problem and declares the unit defective and will be replaced... thanks ante...  ;)
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
