Jump to content
Electronics-Lab.com Community
Posted
Hi Vivek,
I haven't seen a preamp circuit for a dynamic mic for many years. I use electret mics now.
Look for Dynamic Microphone Preamp Circuit in Google. There are many circuits, some are good and many are horrible.
Posted
Look at XLR Connector in Google. It shows the balanced signal pins and the ground pin of your microphone. Shure's datasheet for your microphone also shows which pin is which.
Most of the "horrible" schematics of preamps with only two wires for the mic are for cheap toys. Your Shure professional microphone is not used in toys, it is balanced.
Posted
I got some information on XLR pin mics.
I think there is one "Normal polarity" and another "inverted Polarity"
Should I use these like: normal to "non-inverting" and inverted to "inverting" ends of an OP amp?
Regards,
V
Posted
You cannot connect anything directly to both inputs of an opamp because the voltage gain would be 200,000 at low frequencies which is way too high. The opamp needs to have negative feedback to reduce the gain to a usable amount. The inputs of an opamp also need to be biased correctly.
Look in Google for Opamp Differential Input Pre-amplifier Circuit that has two inputs for a balanced microphone.
  • 2 weeks later...
Posted
Vivek,
The Shure SM58 provides a positive signal on pin 2 with respect to pin 3 when pressure is put on the diaphragm (when sound hits it). Pin 1 is connected to ground. To connect this microphone to an unbalanced mixer, you just connect pins 3 and 1 to ground and use pin 2 as your signal output. This is all you have when you purchase a cable with XLR on one end and 1/4" phono jack on the other end.
You will not see any difference in the output unless you are running massive lengths of microphone cables.
MP
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
