circiut help reqest
steven
here is a circiut i once collected off the net , its suposed to be some kind of sensitive gravity wave detector , but the details of this ciriut aint to good can some one write the pin numbers down on the circiut here so that i will know what pins are used, on the net there are few tl082 ics listed but some have different details about them , so i dont really know which ones being used in this circiut , i have 2 of these ics but they have the texas instraments logo on them and the details on these are 15c5r5m and under it is tl082cp  is this the correct ic to use , allso before i make this circiut is there any improvements i can make to it to make it even more sensitive, or shall i just stick to the way it is, and allsao i dont have a 2.5uf electrolytic so can i use a 2.2uf and as for the mylar or metal cap i dont have them but can i use something else or what can i use in its place and is the value really that criticle or not
The circuit will work fine with just about any opamps. TL082 dual opamps are made exactly the same by many companies, look at the datasheet to see which pin is which. Most other dual opamps have the same pins numbers.
The circuit is designed to be powered by two 9V batteries, one for +9V and the other for -9V with them joined together at ground.
The 2.5uF electrolytic input capacitor is supposed to pickup the gravity wave somehow. If you use a different one then it might be better or it might not work.
The 2000pF capacitor cuts hiss. Its value can be anything from 1000pF to 4700pF. If a ceramic disc cap is used then it might pickup noises like a microphone because the gain in the circuit is very high.
:)i need to redraw the design to a more simplified format so it will be easy to biuld by but despite the data sheet posted here i need to know on the circiut diaghram which pins are the pins as listed on the data of the real rectangle shaped ics which unnumberd pin on the actuall  circiut diagram is which are the pin details the same as one of the tryangles in the data sheet here , remeber the tryangle symbol suposeing to represent the actual rectangle shaped chip , i get confused at times myself
No Steven,
Look at the pins on the TL082 that Hotwaterwizard attached. It shows a dual opamp. A dual opamp has two opamps in it.
Pin 7 is the output of the second opamp. You have it connected to the positive battery by mistake.
Pin 1 is the output of the first opamp. You don't have it connected to the first volume control, you have it connected to pin 2 by mistake.
thankyou audio guru and john thats what i wanted to know on the first schematic that uses tryangles i wanted to know the pin numbers for it to compare with the data sheet  so to make it easyer to biuld , well it helps to know  that now i can get it right , we wouldent of had to go through all the trouble if the designer of the first circiut that i posted, which i got from the net,  put the pin numbers in  the first place  thanks guys anyhow . audio guru ill put the batterys around the right way .
